-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   SRS light and code 222 (https://volvoforums.com/forum/volvo-850-16/srs-light-code-222-a-751/)
guptash Dec 16, 2004 11:45 PM
95 850 GLT Wagon, non-turbo
SRS light is ON and the code is 222. I believe this means "Passenger module, break in wiring".
Any advice on what I should do will help.
Regards,
tech Dec 17, 2004 10:43 AM
RE: SRS light and code 222
I forget what code that is for.Just a quiestion when you repaired your seat did you take it out?If you did and if you turned the key on that might have set the code.Try to clear it and see if it comes back.
guptash Dec 17, 2004 12:54 PM
Hi Tech,
No, I did not remove the seat to activate SRS code 222. This light had been ON even before I worked on the seat.
Your help is awesome.
Regards,
tech Dec 17, 2004 01:27 PM
No problem any time
guptash Dec 17, 2004 11:48 PM
I am unable to reset the code. This is what I have done so far:
1. check the code twice and both times it was 222.
2. Then I press the button and keep it pressed for 10 secs, after that when the red LED comes on I press the button again and keep it pressed for 10 secs.
3. Repeat step 2 again.
4. Check for code and it still shows 222, did I do something wrong?
I am hoping that if I can reset successfully then the SRS light may not come on again.
Regards,
tech Dec 18, 2004 12:42 AM
http://brickboard.com/FAQ/700-900/ElectricalSRS.htm
Follow instructions from link and make sure that is what you did and let me know.
guptash Dec 18, 2004 12:42 PM
Yes, I have followed the instructions but still get the code 222. I know I am not doing something right. I repeat what I do: Put jumper in B5, press button and keep it pressed for 10 secs, release button, wait for LED to light up and while it is lit I press the button again and hold for 10 secs. I then check the code and still comes to 222.
The last thing I am going to try is to take off the battery connection and see if that will reset the code, will it? I think somewhere on the net I read someone tried this and it worked.
tech Dec 18, 2004 12:52 PM
You can give it a shot.While you have them apart.After disconnecting the battery touch them both together or hold them together for a minute or 2 then connect and see what happens.I would leave it disconnected for about 10 to 15 min.If not let me know if it doesn't work and then we will try something else.
guptash Dec 18, 2004 05:56 PM
No luck with the battery disconnection just as you suggested. I tried the traditional method both before and after the battery disconnection no success with that either.
Any suggestions?
Regards,
tech Dec 18, 2004 07:45 PM
I believe the code 222 is for the passenger side air bag.Disconnect the battery again.Remove the glove box insert.There should be 6 or 8 torxes 25 screws and remove the arms from the glove box door.Insert a small screw driver into the slott and pull the arms out.Once you have done that look for the plug for the passenger air bad.Unplug the air bag.Using a small peice of wire or a small paper clip jump the 2 wires in the harness together.reconnect the battery and check for codes again if there is a code try to erase again if it clears this time the passenger air bag is bad.If not in may be the crash sensor.Try that and let me know.
tht828 Jan 5, 2005 08:27 AM
One major piece of advise. MAKE SURE you disconnect the battery at least 5 minutes before disturbing the airbag. You don't want to accidently activate the airbag.
