Static noise above passenger door
Old May 23, 2008 | 05:43 PM
StrangeBrew's Avatar
Default Static noise above passenger door
I'm making a to-do list of small repairs for my g/f's new-to-her '95 850 turbo. Among other things, I noticed an odd hissing, static-like noise coming from above the passenger side door. Upon further inspection I found the noise coming from a small plastic piece directly behind the oh-sh*t handle. There is one on the driver's side as well, but no noise there. Thepiece is about 3/4" square with small circle in the middle. The radio drowns it out pretty well, but it's pretty bothersome if you're in the passenger seat. The noise is there whether the car is stopped or moving.I've poked around the forums, but can't find any info. Anyone know what this piece is? Is it part of the stereo or alarm? Never seen anything like it. Looks too small to be a tweeter for the stereo. Thanks!
-Colin
Old May 23, 2008 | 06:27 PM
JPN's Avatar
JPN
Default RE: Static noise above passenger door
Right behind the oh $hit handle, there is a temp sensor for Electronic Climate Control system. Someone said it was a cooling fan kind of device, but it is supposed to be a temp sensor. Remove the handle and visually inspect the sensor. The handle is held bytwo10mm bolts. This person said that his sensor was clogged with dust and after cleaning it, the noise he had stopped.
JPN
EDIT: Spraying the electrical connection with a can of contact cleaner is a nice follow-up.
[IMG]local://upfiles/6892/100E6569FA4346BCA59130588B8D41DB.jpg[/IMG]
Old May 23, 2008 | 11:26 PM
Ahhhh, it all makes sense now. I'll be taking that apart first thing in the morning. Maybe that will help with my other ECC issues.Thanks for such a thorough response!
-Colin
Old May 24, 2008 | 05:07 AM
JPN's Avatar
JPN
One correction; the oh cr@phandle is held by two 10mm bolts instead of Torx. I sucked[8D].
JPN
Old May 26, 2008 | 05:53 PM
Simple fix - after removing the "oh-$h*t" handle and the cover for the temp sensor, i just cleaned out the dust bunnies with a small phillips screwdriver. Blew some compressed air through it, and re-assembled. All is quiet in my car now
PS - The noise was caused by dust getting clogged in the tiny fan that blows across the cabin temperature sensor.
Old May 26, 2008 | 05:56 PM
JPN's Avatar
JPN
Glad to hear your "Oh funk" handle is quiet now.
JPN
jktiffin
Oct 26, 2006 11:07 AM
br549
Sep 20, 2006 08:42 PM
vsan
Aug 31, 2006 10:56 PM
Red XC
Apr 6, 2006 01:01 AM
bluemtn
Feb 23, 2006 12:07 AM
