Stereo Amp
Old Jun 2, 2012 | 12:27 PM
Bobbler's Avatar
Default Stereo Amp
Hey i have a 1996 850 platinum i recently installed an amp from a 2000 s70 and deck from a 1999 v70 r. The problem is that after i installed evrything it worked perfectly then out of no where two rear most speakers died. As I am pretty sure the amp is the cause can anyone tell me if the amp has internal fusing or how many channels the amp has? Also possibly what the wire colours for the two rear most speakers are?
Old Jun 2, 2012 | 03:20 PM
I'm not sure but if you simply disconnect the amp the R stereo should sound just as good without it.
Old Jun 2, 2012 | 04:40 PM
Bobbler's Avatar
No the stereo won't work with out the amp I originally thought that since they have the same plugs but nothing works on deck without amp
Old Jun 2, 2012 | 10:24 PM
I just pulled an amp from a jy car and the harness was plugged into the amp then from the amp into the radio. Maybe you need to make sure it's hooked up right. These radio's work well without the amps plugged in.
Old Jun 3, 2012 | 08:00 AM
Bobbler's Avatar
All is plugged in and the deck is the three cd changer in dash it does not work in my 850 without amp
Old Jun 6, 2021 | 06:25 PM
bazza ryan's Avatar
Default amp
Without my amp pluged in radio does not work.
Old Jun 7, 2021 | 03:29 PM
are you replying to a zombie thread or starting a new discussion on your issue? When you say radio does not work do you mean no sound or no power to the head unit?
Old Jun 7, 2021 | 05:13 PM
bazza ryan's Avatar
radio turns on no sound
Old Jun 8, 2021 | 11:53 AM
ok so the first thing is to make sure you haven't blown a fuse to the power amp. next is I'd check for wiring/connector issues. Usually the amp is switched on by the head unit so you need to make sure the amp is getting that signal.
nkhlystov
Dec 14, 2010 01:30 AM
huzzsaba
Apr 2, 2009 05:35 PM
dibz1064
Mar 21, 2009 09:19 AM
bedrock
Apr 19, 2008 10:13 PM
azmark
May 6, 2006 10:31 PM
