strange noise when turning right
Old Aug 2, 2006 | 12:59 PM
rejeep's Avatar
Default strange noise when turning right
really strange problem started happening when I turn my 850 right and right only..
I get a very loud hum/whir... any thoughts
Old Aug 2, 2006 | 01:49 PM
code33's Avatar
Default RE: strange noise when turning right
Does this happen all the time? Slow or fast?
How far does the wheel have to be turned to make that sound?
Old Aug 2, 2006 | 02:00 PM
rejeep's Avatar
both slow and fast.. more fast then slow.. its fairly constant.
the wheel only needs to be turned a few inches to notice...
I have already checked the wheel well from obstructions.. or loose inner fender.. but it doesnt sound like plastic
Old Aug 2, 2006 | 09:28 PM
code33's Avatar
I want to say wheel bearing but it doesn't sound obvious.
Check the tightness of the lug bolts.
Jack up the front right wheel, turn the wheel to the right and spin the tire by hand. Also, pull on the wheel to see if there is any play.
Old Aug 2, 2006 | 10:46 PM
Also make sure the Axle nut is torqued properly.
Old Aug 3, 2006 | 05:33 PM
rejeep's Avatar
will check..
thanks
Old Aug 4, 2006 | 05:25 PM
rejeep's Avatar
lugs and axle nut were tight.. any other thoughts?
Old Aug 4, 2006 | 06:19 PM
code33's Avatar
Did you get a chance to spin the tire by hand in neutral w/ wheel turned to the right?
Old Aug 8, 2006 | 12:37 AM
Maybe Bad wheel bearing.
Old Aug 9, 2006 | 10:25 PM
rejeep's Avatar
I got a chance to jack it up and spin the tire in neutral
well no sound.. I turned the wheel to the right and tried.. nothing either.
How would I check for a wheel bearing?
The car also needs a balance.. as I am getting a vibration from the front.. or this vibration might be from the noise?
Old Aug 10, 2006 | 12:21 AM
The wheel bearing usually makes a humming noise when it goes bad.
Make sure all bushings and swaybar links are good.
Old Aug 10, 2006 | 02:34 PM
cranky's Avatar
I'm tempted to agree with Tech ; wheel bearing
Old Aug 10, 2006 | 08:36 PM
96DTM850's Avatar
VERY EASY to check wheel (hub) bearing. Simply jack up the front of the car, with the transmission in neutral, take one hand and hold on to the spring while spinning the wheel with your other hand. If you feel any slight vibration, it's bad or going bad. A good hub bearing, you would not be able to feel anything on the spring. Also, check your CV joints just in case if you suspect the axle.
Old Aug 11, 2006 | 02:07 AM
rejeep's Avatar
I had the hubs done by my dealer three years ago when I bought the car...
any idea on how long these last...
should I even bother talking to the dealer.?
Old Aug 11, 2006 | 01:20 PM
96DTM850's Avatar
ORIGINAL: rejeep
Hub bearing should last 100k+ miles...considering you're not off-roading the car, running over curbs, animals, people (hey, it happens)...haha...basically not abusing the car. If it's making a clunk type noise when you turn, I would suspect the CV joint (axle). Check to make sure the rubber boot that encapsules the CV joint is not ripped and all the grease is gone.
Old Aug 11, 2006 | 09:34 PM
rejeep's Avatar
no its deff not a clunk.. the boots looked good and intact... its a metalic whir... and the more i think about it it sounds like my jeep hubs when they go bad..(that I offroad)
Old Aug 11, 2006 | 09:38 PM
  #17
96DTM850's Avatar
Well, Could be a bad hub bearing then. Check that first.
Old Aug 11, 2006 | 10:10 PM
  #18
How about the tires?
They aren't feathered bad are they?
Old Aug 12, 2006 | 01:56 PM
  #19
rejeep's Avatar
tires are actually feathered and irregularly worn..
Old Aug 12, 2006 | 02:09 PM
  #20
That would cause the noise as well.
If the backs are better try swapping then driving and see if the noise is gone.
