strut squeek/loose?
Hi
We have noticed squeaking from the front end of our V70 recently. When I pop the hood to look at the struts, the top of the drivers strut nut/shaft can be turned rather easily. (the nut is tight) The passenger side will not spin at all. Is it normal to be able to turn the strut shaft like this? Thanks for any thoughts on this BTW, the shocks still dampen the ride just fine, springs keep the car even both sides Pete |
Originally Posted by pconfar
(Post 255489)
Hi
(Post 255489)
Hi
Originally Posted by hookuspookus
(Post 255605)
zap the nut with a air gun pete
Negative! The problem is the strut mount. If it turns, it's destroyed. Best to get one of the heavy duty mounts from a XC90, or the IPD heavy duty mounts - they last longer. If you happen to loosen that nut, you face a spring becoming unsprung - and that's a bad thing! |
Originally Posted by vjaneczko
(Post 255682)
Negative!
Strut mounts need to be replaced. It is a good idea to also replace the spring seats when you do this job.
Thanks guys
Our car has enough miles on it that replacing strut/mounts seems like a very reasonable thing to do. Thanks again Pete |
| All times are GMT -5. The time now is 12:25 AM. |
