strut squeek/loose?
Old Feb 6, 2011 | 05:13 PM
pconfar's Avatar
Default strut squeek/loose?
Hi
We have noticed squeaking from the front end of our V70 recently.
When I pop the hood to look at the struts, the top of the drivers strut nut/shaft can be turned rather easily. (the nut is tight) The passenger side will not spin at all. Is it normal to be able to turn the strut shaft like this?
Thanks for any thoughts on this
BTW, the shocks still dampen the ride just fine, springs keep the car even both sides
Pete
Old Feb 7, 2011 | 11:00 AM
NCdad's Avatar
Originally Posted by pconfar
Hi
Pete
I had a similar problem with my 95 Volvo 850 GLT when I bought it. The strut mounts had to be replaced. The noise went away.
Old Feb 7, 2011 | 12:13 PM
hookuspookus's Avatar
Hi
Pete
zap the nut with a air gun pete
Old Feb 7, 2011 | 07:12 PM
vjaneczko's Avatar
Negative!
The problem is the strut mount. If it turns, it's destroyed. Best to get one of the heavy duty mounts from a XC90, or the IPD heavy duty mounts - they last longer.
If you happen to loosen that nut, you face a spring becoming unsprung - and that's a bad thing!
Old Feb 8, 2011 | 08:28 PM
Originally Posted by vjaneczko
Negative!
who said loosen it ?
Old Feb 8, 2011 | 08:33 PM
family XC70's Avatar
Strut mounts need to be replaced. It is a good idea to also replace the spring seats when you do this job.
Old Feb 10, 2011 | 09:43 PM
pconfar's Avatar
Thanks guys
Our car has enough miles on it that replacing strut/mounts seems like a very reasonable thing to do.
Thanks again
Pete
daver80
Oct 25, 2011 10:30 PM
daver80
Jun 25, 2011 10:08 AM
jpjmustang
Jun 3, 2011 09:56 AM
cjaama
Dec 12, 2009 07:23 PM
cool_kyle_3000
May 30, 2006 10:56 PM
