stuck in 3rd gear?
Old Sep 29, 2008 | 01:05 PM
Kyla's Avatar
Default stuck in 3rd gear?
I have a 93 850 GLT automatic with 140,000 km
I started to have trouble with a flashing up arrow on the dash. ABS light is on. Check engine light on sometimes. Now the car is only in 3d gear and wont shift up or down. The code I am getting is 3-2-3 which is the speed sensor. Coulda faulty sensor cause this problemor doI need a new transmission?
Old Sep 29, 2008 | 04:42 PM
Ozark Lee's Avatar
Default RE: stuck in 3rd gear?
Classic PNP switch symptoms. You can often get it to work again by quickly "rowing" the shifter back and forth from low to park a dozen times or so. Even if it starts working again you will need to address the problem by replacing the switch.
What port did you read the codes from? The transmission is port A-1 and I show 3-2-3 as a torque converter lock failure.
On my son's car, the only onewhere I have had PNP problems, it didn't want to work correctly until the transmission codeswere cleared.
...Lee
Old Sep 29, 2008 | 05:02 PM
Quick Brick's Avatar
Hello Kyla,
[sm=welcomesign.gif]to the forum.
This is a link that you may find useful.
http://volvospeed.com/Repair/a1.html
If you go to the main page you will also find info on a number of things that a first time Volvo owner can do for themselves. Read carefully and if you have any questions at all just post them here.
[sm=icon_cheers.gif]
(such a ham)
Old Sep 29, 2008 | 05:05 PM
Kyla's Avatar
I changed the PNP switch and cleared the codes. The first short test drive the car worked perfectly but when it was driven again it went to 3rd gear and stayed there. The 323 code came back and the up shift light also came on. My information says 323 is the speed sensor, is it?
Old Sep 29, 2008 | 05:35 PM
What are you using to decifer the codes that you are getting?
Is/are the codes in a manual and if so, which one?
Old Sep 29, 2008 | 07:35 PM
Ozark Lee's Avatar
Did you go through the alignment procedure on the switch? It is very sensitive to alignment. One of the best procedures I have found without the alignment tool is here with a mirror:
http://www.matthewsvolvosite.com/cha...?p=57963#57963
...Lee
Obelix
Jun 20, 2022 08:40 AM
Kyle Balents
Dec 9, 2014 01:00 AM
walthevolvoguy
Jan 3, 2012 12:55 PM
drgonzophd
Aug 31, 2011 07:42 AM
gratefulvolvo
Jan 3, 2008 08:28 PM
