Sun roof
Hi
I tried to turm my manual sunroof into an electric version. I bought, sunroof motor control module switch & cover trim with lights in I found the wiring harness to the roof & made up a patch cable to get the electrics to the control module. But then i realised there was no where to mount the motor, if i take the manual winder assembly off. I think I have outwitted myself! Is there a different mounting assembly for the motor than the manual version? My assumption was take the handle off & fit the motor it now appears to be wrong. Any thoughts! regards Martyn |
RE: Sun roof
I think there is an assembly you will need to buy.
See if you can find a car in a salvage yard near you to look at and see what else you will need. |
