suspension issue
ok so.. when im driving...normal.. the wheel is turned to 11o clock driving strait..
when i let off of the gas the wheel will jerk right when i hit the brakes.. the wheel straitens out.. and still driving strait.. i thought it was cause of my srtuts but i just replaced the struts strut mounts and spring seats.. any ideas? |
Maybe a bearing. Just take off the wheel and look around for loose or worn out parts.
do the bearings for these need pressed out?
i would assume they do.. how ever i saw a write up and it didnt mention it |
I'm pretty sure they do. IIRC I had to do something with the bearing on mine and me and my dad had to go to his work to use a bearing press.
Originally Posted by im faster
(Post 187091)
they bearings DO NOT! need to be pressed out. the bolt in with four bolts from the back side of the hub.
fairly easy job to do right in the drive way. |
well thats gohod,,
im sure it needs and aligmet but i figured there was something else wrong and i should fix it before ad alignment |
