suspension issue
Old Oct 14, 2009 | 04:07 PM
im faster's Avatar
Default suspension issue
ok so.. when im driving...normal.. the wheel is turned to 11o clock driving strait..
when i let off of the gas the wheel will jerk right
when i hit the brakes.. the wheel straitens out.. and still driving strait..
i thought it was cause of my srtuts but i just replaced the struts strut mounts and spring seats..
any ideas?
Old Oct 14, 2009 | 04:58 PM
gilber33's Avatar
Maybe a bearing. Just take off the wheel and look around for loose or worn out parts.
Old Oct 14, 2009 | 06:17 PM
im faster's Avatar
do the bearings for these need pressed out?
i would assume they do.. how ever i saw a write up and it didnt mention it
Old Oct 14, 2009 | 06:48 PM
gilber33's Avatar
I'm pretty sure they do. IIRC I had to do something with the bearing on mine and me and my dad had to go to his work to use a bearing press.
Old Oct 14, 2009 | 11:23 PM
gdog's Avatar
any ideas?
Had the alignment checked after you did the front end work? If not, start there.
Old Oct 15, 2009 | 01:33 AM
850tony's Avatar
they bearings DO NOT! need to be pressed out. the bolt in with four bolts from the back side of the hub.
fairly easy job to do right in the drive way.
Old Oct 15, 2009 | 11:00 AM
im faster's Avatar
well thats gohod,,
im sure it needs and aligmet but i figured there was something else wrong and i should fix it before ad alignment
rspi
Dec 24, 2011 11:50 AM
TWR1980
Jan 12, 2011 10:21 PM
wso_1
Oct 22, 2010 08:39 AM
qstyle
Feb 5, 2009 02:44 PM
