The Sweet Smell of a Coolant Leak
Old Sep 29, 2009 | 12:50 AM
kapka42's Avatar
Default The Sweet Smell of a Coolant Leak
So the weathers been getting colder and inevitability i turned my heat on and discover my "new" car has a coolant leak. The heating has that typical syrupy smell. I did a quick forum search and googled it and nothing. Is there anything common that goes wrong with 850s that i can look for?
Old Sep 29, 2009 | 10:58 AM
JPN's Avatar
JPN
Pressure-test the cooling system.
With the hood/bonnet open, start the engine and look for leak. Stop the engine immediately if coolant sprays out.
Check:
- Radiator, especially the seam between the aluminium & resin portions.
- Check the reservoir cap.
- Check water pump by removing the 12mm bolt on the timing belt cover and wiggle it upward. The water pump is on lower-left in that area.
- Check all coolant connections. The heater core may leak with age; check the connections at the firewall.
- Check in side the cabin under the dash.
As a temporary remedy, make sure to keep the correct coolant level. NEVER drive with the coolant reservoir low.
Others will be chiming in soon.
JPN
Old Sep 29, 2009 | 01:47 PM
fcpgroton's Avatar
Former Sponsor
Are you getting an coolant on the passenger side of the car? It sounds like your heater core may be on it's way out.
Old Sep 29, 2009 | 04:53 PM
VTBricked's Avatar
X2. Pull the rug back on both sides of the tunnel under the dash. Remove the side panels - 1 screw each toward the rear of the panels. Look under the heater core for signs of leaking. Even if you see no signs of leaking onto the tunnel, odor inside the cabin indicates a heater core leak. It's not a bad DIY if you tackle it yourself and there are writeup aplenty.
Old Oct 2, 2009 | 07:02 PM
kapka42's Avatar
when i orginally bought the car, the coolant resevoir was cracked and leaking coolant, im supposing cause the shop owner had some idiot top off all the fliuds and he prob overfilled it. I replaced the piece and the coolant is about halfway between the min and max line, and hasnt moved since. im up at school atm but should be home ina week or two, ill check it out and post back
p.s. I dont know if it makes any difference, but a while back my a/c got messed up too and i was checking the system, and the pressure at 120psi
Old Oct 3, 2009 | 11:10 AM
JPN's Avatar
JPN
If the coolant level is stationary, I can only assume that the leak has stopped and residual coolant somewhere is giving you the odor.
How's the condition of the coolant in the reservoir? I hope there is not a sign of oil/fuel.
JPN
Old Oct 4, 2009 | 02:34 PM
kapka42's Avatar
when i installed the new resevior, i cleaned it out first and transfered the original coolant into it. It didnt seem like there was any oil or contaminants in there
Old Oct 4, 2009 | 10:54 PM
JPN's Avatar
JPN
That is strange, that the coolant has no contamination and the level has not changed, yet you can still smell it.....
I can only assume that there is a very slight leak, that produces minimal steam under pressure. I would check rubber hose connections/cooling system components to see if you can locate signs of leak.
JPN
kapka42
May 20, 2011 03:32 PM
cmayo313
Mar 18, 2011 12:09 PM
zacharyzoosh
Mar 8, 2011 09:55 PM
uncle
Jun 30, 2007 07:51 PM
spinningcain
Jan 19, 2006 07:56 PM
