Testing Engine Fan Relay
Old Nov 9, 2007 | 06:47 PM
  #21
Default RE: Testing Engine Fan Relay
The 3 pins are one is ground one is for the fan and the other is for the compressor.
Old Nov 10, 2007 | 03:43 AM
  #22
axelm's Avatar
I don´t understand the design. Why does the pressure switch have a signal for the fan? The objective is to measure the pressure on the high side. The fan stages are controlled by other pins directly from the ECU. Is the fan signal on the pressure switch some kind if feedback to the ECU telling it that the fan is effectively spinning, in case the relay goes bad?
Old Nov 10, 2007 | 08:40 AM
  #23
I never really looked into the circuit that much but I know thats how it works.
I have had bad high pressure switches that only the compressor would come on but not the fan so the A/C would only work till the pressure got to high then shut off.
And I have had bad high pressure switches where the compressor would not ever come on but the fan would work.
Old Nov 10, 2007 | 05:09 PM
  #24
axelm's Avatar
Tech, thanks a lot. You have been very helpful as usual.
Regards
Old Jun 30, 2013 | 04:40 PM
  #25
pumpguy's Avatar
Default intermittent cooling fan
the radiator cooling fan sometimes doesnt work. i can turn off the car wait thity minutes- restart and it SOMETIMES runs. can someone please give input. this is college daughters car- third kid to take through college.
Old Jun 17, 2016 | 12:22 AM
  #26
Luke Woessner's Avatar
When you turn on the A/C compressor, does the radiator fan kick on automatically? To test the radiator fan which plug from to relay do you connect directly to a 12V source? Left, right or middle? What number goes to what battery terminal? (+ or -)
Old Jun 17, 2016 | 12:24 AM
  #27
When you turn on the A/C compressor, does the radiator fan kick on automatically? To test the radiator fan which plug from to relay do you connect directly to a 12V source? Left, right or middle? What number goes to what battery terminal? (+ or -) I'm trying to discern whether I need a new fan assembly, relay, or switch. It's been an intermittent problem for me for a while...
ingydrummer
Sep 16, 2013 06:57 PM
samtheman77
Nov 15, 2009 10:27 AM
dads 740 turbo
Oct 24, 2008 06:54 PM
