Those foggy tail lights...
Are they foggy on the inside or the outside? And when you say Fog do you mean that the plastic is worn/dull/scratched on the outside or could it be condensation buildup on the inside?
If dull on the outside, I'd look to some wet sanding with a very fine grit, and then coat them with Armor All or some other plastic rejuvenator.
If its condensation on the inside, disassemble them and dry them out well.
Ahh, gotcha. Yeah, do the wet sanding - probably use several grits to remove any fogging. Maybe after that you can shoot it with a rattle can of clear coat. That's just a thought so I don't know if it'll work well.
+1 on the lens cleaning kit. They even have one that attaches to a cordless drill now, which saves your arms. That's what I did on mine, then put nightshades on them, then clearcoated them. After the clearcoat cured, I wet sanded that too.
Attachment 2851
Attachment 2851
88740gle
Nov 13, 2015 08:13 AM
buellfire
Jun 20, 2009 12:37 AM
