Throttle Body Engine Light
Old Sep 25, 2009 | 02:36 PM
SAFVet's Avatar
Default Throttle Body Engine Light
My 97 850 T5 is throwing an intermittent code about "no voltage from throttle body". Is this due to a fault in the throttle position sensor or could it be something else?
Thanks!
Old Sep 25, 2009 | 07:15 PM
Ozark Lee's Avatar
What is the actual P code? Some of the generic translations don't translate to Swedish very well.
...Lee
Old Sep 26, 2009 | 09:59 PM
sconeman's Avatar
I can't think of anything else but the TPS that's electronic and on the throttle body. I'd check that out first.
Old Sep 27, 2009 | 08:16 AM
JPN's Avatar
JPN
If the scanner being used reported the TPS was bad, it probably is the TPS/its electrical connections that needs attention (Volvo's self-diagnostic isn't very accurate sometimes).
I would try to clean the electrical connector with a can of electrical contact cleaner and clean the throttle body. Do this with the ignition off, and it it were me I would also disconnect the negative battery cable, which is kind of a pain in the south end.
Give us updates if you would,
JPN
86volvoguy
Apr 20, 2017 10:50 PM
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
proudmonkey
Jul 21, 2005 10:01 PM
wavewright
Apr 9, 2005 06:15 PM
