throttle hesitation
Old Jan 9, 2005 | 01:44 PM
knight rider's Avatar
Default throttle hesitation
I have been having this problem for a while in my 94' turbo 850 wagon. i will be crusin at about 65 mph and I will lose acceleratiion in pulses. I tried shifting into neutral and revving when it happens and it seems fine. When the check engine light came on there was code for o2 sensor and knock sensor. I replaced the o2 sensor, and it was fine for a while. Now about two weeks later the problem is back and I have not taken it back to see if the o2 sensor went bad again. Could this be from the knock sensor
Old Jan 9, 2005 | 07:34 PM
Default RE: throttle hesitation
I could be possible that the knock sensor is bad.Did you replace both of the o2 sensors or just 1?Most of the time it is best to replace both sensors because when 1 goes bad it will make the other one go bad to.
Old Jan 9, 2005 | 10:03 PM
I just replaced the one at the air filter. Where is the other one?
Old Jan 9, 2005 | 11:02 PM
I just realized that when I asked for o2 sensor, he gave me the maf. where are the two o2 sensors?
Old Jan 10, 2005 | 12:44 AM
The o2 sensors are in the exhaust system between the manifold and the front part of the muffler.You can't miss them they are screwed into the exhaust pipe with wires coming out.
Old Jan 10, 2005 | 12:52 AM
I did research back to the quote I resieved from the volvo place. It was for replacing teh maf, and then the knock sensor. Where is that located and would that cause the hesitation. I put a bosch maf on there and the problem is still there.
Old Jan 10, 2005 | 12:58 AM
The knock sensor is located on the engine towards the front of the car by the starter they are round sensors with screws going through the center.they are black and have a plug going to them.
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
ZX2Fast
1998-2000 model year V70
Mar 9, 2014 01:35 PM
turbo940v
Oct 2, 2010 02:38 AM
s40volvoH
Mar 18, 2005 06:43 PM
