Is it the tie rods?
Old Jun 28, 2011 | 03:56 PM
TonyS's Avatar
Default Is it the tie rods?
I have been getting some shuddering upon braking with my 1996 NA 850 wagon. It's especially noticeable upon stopping from freeway speeds. Mostly this seems to come from the front driver's side. Previously I've replaced the front rotors and pads, thinking that the rotors were warped. No change. Someone here suggested that it might be the tie rods. I did the 3/9 give-it-a-shake test and noticed some movement, plus a light thunking noise. This afternoon I put a new inner and outer tie rod on the driver's side, hoping that would solve the problem. After I finished I put the tire back on and again rocked the tire. Can't say it's rock solid. There's still some movement, and still that very light thunking sound. Suggestions?
Old Jun 28, 2011 | 04:31 PM
MattyXXL's Avatar
What do your control arm bushings and ball joint look like?
Old Jun 28, 2011 | 05:32 PM
TonyS's Avatar
When I grab the tire at 12 and 6 and shake I'm not getting any movement. The control arms were were replaced by the previous owner about 35,000 miles ago. Which is not to say it couldn't be the control arms.
Old Jun 28, 2011 | 06:25 PM
MattyXXL's Avatar
Id put a pry bar in between the control arm and the mounting area and see if you have any play.
You should do it with with the wheel off so you can see whats moving
Old Jun 29, 2011 | 07:43 AM
Rickford's Avatar
+1 On the ball joints. Mine were tight and on the newer side when I hit a friggen pot hole. Tt trashed the pass side ball joint and gave me a slight wander which was gone after replacement and alignment.
PANTYEATR
Jun 10, 2011 06:13 AM
myfakename
Feb 22, 2008 01:23 PM
buckquark
Oct 29, 2007 10:47 PM
SDozier
Jun 27, 2006 12:40 AM
EBITDA
Nov 8, 2005 09:14 PM
