Timing belt change question
Old Apr 3, 2013 | 11:34 PM
Psaboic's Avatar
Default Timing belt change question
Hi All,
Its getting close to the time for me to change the timing belt on the 95 850 Turbo again. I last changed it about 8 years and 70,000 miles ago, so it is definitely due. When I changed it last time, I put on a new belt, a new tensioner, and new pulley/rollers plus a water pump. I also changed the serpentine belt, Serpentine belt tensioner, and all pulleys /rollers for the serpentine belt system.
This time around do you think I should change everything again, or just the timing belt, tensioner, and rollers. In other words if it was you, what would you do
Many thanks,
Glenn
Old Apr 4, 2013 | 04:12 AM
I would have all parts on deck and change what is worn or in need of changing. My rule is to change the belt and both rollers. I only do the water pump if it's leaking (or every other change) and the tensioner if it's leaking.
brick8
Sep 25, 2014 06:56 AM
Psaboic
Oct 29, 2006 10:28 AM
postdoc99
Oct 11, 2006 01:12 AM
thejman
Jun 9, 2006 09:45 PM
Psaboic
May 9, 2006 10:36 PM
