Timing Belt Service Problems - Stripped Tensioner Pulley Bolt
Old Feb 28, 2019 | 09:09 PM
RedSweed's Avatar
Default Timing Belt Service Problems - Stripped Tensioner Pulley Bolt
I was changing the timing belt in my '97 850 t5 and low and behold I stripped the T45 bolt that holds the tensioner pulley. Stripped bolts on say a thermostat unit are not so bad because you can take a drill to it; This bolt is at the wrong angle however. Any tips on how to get this bolt out?
Old Mar 1, 2019 | 04:25 PM
ugh. See if you can find a bolt extractor kit (HarborFreight/Autozone/Sears etc may have something). You may need to hammer in a hex or similar that is slightly larger than the T45 - which may require removing parts to make some working room.. Did you try and prep the bolt with PB Blaster or heat to crack it?
Old Mar 1, 2019 | 06:16 PM
firebirdparts's Avatar
Those are terrible. I suppose an "easy" solution would be to weld a nut on there.
Those things are so hard to get to with the perfect tool that fits perfectly, I shudder to think what it would be like to get one out with the wrong tool.
Old Mar 2, 2019 | 05:42 PM
860ARE's Avatar
I stripped mine and just left it until next change. I heard of people drilling in from the wheel arch and sending in a socket straight at it no problem . Better than bent valves
Old Mar 3, 2019 | 10:49 AM
That is probably what I'd do. You can easily patch up the inner fender or find a rubber plug to close up until the next time - lol, Volvo should have done that to start with!
Old Mar 3, 2019 | 12:38 PM
860ARE's Avatar
Excattly. Spray little fluid film and cork it. No problems at all
gorillajin
Jan 29, 2010 09:17 AM
PlattytheVolvo
Apr 27, 2009 10:43 PM
dads 740 turbo
Nov 6, 2008 07:50 AM
simeyrocks
Jan 26, 2008 09:02 AM
MikeySq
Oct 18, 2006 10:01 AM
