Tire size
Hello, im just wonder if any could tell me the tire size needed to go to 17 inch rims. my stock tires are 195/60/15. i was thinking maybe 205 45 17's would work? or 215 40 17
Um...17 by what?
There 10 inches wide
This I want to see. 10 inch wide rims in the stock wheel well :confused:
Have you tried to mock them up on the spindles yet and see if they will turn in front? |
2 Attachment(s)
I need tires before i can actualy put them on and let the car down. i had the car jacked up the other day to take the fluid line off the rack and pinnion. so i decided to stick one on. the only way they would fit with the tires that are curently is for it to be jacked. There is alos about an inch and a half wheel spacers on it.
Attachment 5730 Attachment 5731 |
They are actualy 17x8 . there Borbet type m
You can try this site:
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch RSPI posted this a while back: The 215/45/17 do rub a little at lock. Heck, if things are not perfect on my 205/45/17's they rub a little. |
Those look like they stick out 2 inches past the fender. Why would you have such large adapters on those wheels? What are the offsets/bolt pattern on them? I don't get it.
The bolt pattern for the rims are 5x114.3 and the stock bolt pattern as you know is 5x108. The spacers where giving to me for free and i only payed 50 for the rims. The car only has steelies on it and one is bent to hell from the last owner, so i figured i would try and put those rims on. i priced tires today and there $179 a peice for 205 45 17 cooper zeons. i thinking they may rub sticking out that far
