Tire size
Old Feb 17, 2012 | 07:33 PM
Travis124534's Avatar
Default Tire size
Hello, im just wonder if any could tell me the tire size needed to go to 17 inch rims. my stock tires are 195/60/15. i was thinking maybe 205 45 17's would work? or 215 40 17
Old Feb 17, 2012 | 07:34 PM
gilber33's Avatar
Um...17 by what?
Old Feb 17, 2012 | 08:25 PM
There 10 inches wide
Old Feb 17, 2012 | 08:42 PM
This I want to see. 10 inch wide rims in the stock wheel well
Have you tried to mock them up on the spindles yet and see if they will turn in front?
Old Feb 17, 2012 | 08:57 PM
I need tires before i can actualy put them on and let the car down. i had the car jacked up the other day to take the fluid line off the rack and pinnion. so i decided to stick one on. the only way they would fit with the tires that are curently is for it to be jacked. There is alos about an inch and a half wheel spacers on it.
Old Feb 17, 2012 | 09:41 PM
They are actualy 17x8 . there Borbet type m
Old Feb 17, 2012 | 10:34 PM
You can try this site:
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch
RSPI posted this a while back:
The 215/45/17 do rub a little at lock. Heck, if things are not perfect on my 205/45/17's they rub a little.
Old Feb 18, 2012 | 08:46 AM
gilber33's Avatar
Those look like they stick out 2 inches past the fender. Why would you have such large adapters on those wheels? What are the offsets/bolt pattern on them? I don't get it.
Old Feb 18, 2012 | 09:03 AM
The bolt pattern for the rims are 5x114.3 and the stock bolt pattern as you know is 5x108. The spacers where giving to me for free and i only payed 50 for the rims. The car only has steelies on it and one is bent to hell from the last owner, so i figured i would try and put those rims on. i priced tires today and there $179 a peice for 205 45 17 cooper zeons. i thinking they may rub sticking out that far
HummerGuy
Oct 10, 2008 08:02 AM
Meglog
Aug 17, 2006 02:48 PM
postdoc99
Feb 3, 2006 09:38 PM
AaronD81
Dec 7, 2005 09:34 PM
volvobacon
Dec 1, 2005 10:50 PM
