tranny problem- NOT!
![Confused](https://volvoforums.com/forum/images/smilies/confused.gif)
If he changed the whole transmission he more than likely changed the solenoids as well.
If you used the old ones, then that's where your problem is. My transmission sometimes drops out of first gear when I'm coming to a stop and I know the reason is the pressure control solenoid (solenoid #3) but I can't do anything about it.
So what's the common denominator here (assuming trans solenoids were changed out)?
The trans is different; the Trans Controller is different... what about an intermittent fault in the wire harness between the controller and the trans???
You should have some transmission controller codes set; have you read them?
This could be telling: check engine light was illuminated for many months prior to the tranny change out. Code was read as oxygen sensor. (check engine light came on many, many months after tranny problems began). mechanic said both front and rear oxygen sensors were bad, so installed new ones recently. Check engine light still is illuminated. Sheesh. I am going to mechanic No. 5 (local shop that services Volvos only) and will ask about about both these suggestions (harness and codes). Thanks, much Intermittent and electrical problems equal utter frustration (and lots of cash thrown at what is thought to be the problem!)
