Tranny shifting problem
Old Aug 12, 2005 | 01:07 AM
GaryBrad's Avatar
Default Tranny shifting problem
One thing I forgot to mention was a problem I have with my tranny shifting. It does eventually shift to all gears but it really shifts slow into 3rd and 4th. The RPM's go up to 4000-5000 before it shifts. Is there anything I could check while I have the tranny out replacing the main seals.
Old Aug 12, 2005 | 09:41 AM
Ignavus's Avatar
Default RE: Tranny shifting problem
It could be a gummed up trans and/or valve body, or more than likely worn check ***** in the valve body. If you go in there, you really should have the factory manual.
Old Aug 12, 2005 | 05:45 PM
Carbuff's Avatar
ORIGINAL: Ignavus
Would a sticky kickdown cable cause a 3-4 shift to come late?
Old Aug 12, 2005 | 07:32 PM
Ignavus's Avatar
If it is just a late 3-4 shift, then that is usually something to do with the OD solenoid or wiring. I was under the impression that all of the shifts were REAL late. Which could be a totally trashed cable, but usually even with the cable removed the valve body pressures will climb high enough to shift it before 5k. If you go in and find just a trashed cable, consider it a blessing.
Old Aug 12, 2005 | 10:21 PM
I agree look at the kick downcable.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
dtbaker61
Engine & Internal
Jan 1, 2014 11:40 AM
gooproduct
Jul 20, 2007 10:00 AM
joker834
Apr 14, 2006 10:40 PM
my850turbo
Dec 19, 2005 09:19 PM
