Trouble code 123
Old Oct 3, 2013 | 06:56 AM
Dainos's Avatar
Default Trouble code 123
Recently changed my radiator fan along with coolant temp sensor. Now the fan comes on whenever I start the car or the ignition key is in position ii. Also, it stays for for like 2 mins when I turn off the car.
This morning it started having a rough idle and I pulled a 2-1-2 code. Please help
Old Oct 4, 2013 | 04:51 AM
GMurphy's Avatar
What year is your car? Which socket produced the 2-1-2 code? 2-1-2 could mean, "2-1-2 Solenoid S2 circuit shorted to 12 volts" which could be a transmission trouble code OR "2-1-2 heated oxygen Sensor Signal absent or faulty" which is a Motronic 4.3 fuel management trouble code. More info is needed...
Thanks,
Greg
Old Oct 4, 2013 | 08:25 AM
Dainos's Avatar
I have a 95 850 turbo wagon. I used socket 2
Old Oct 4, 2013 | 08:49 AM
awfulwaffle's Avatar
My n/a does exactly what you described when the coolant temp sensor is disconnected. Does your temp gauge read anything as the car war ms up?
Old Oct 4, 2013 | 12:24 PM
Dainos's Avatar
The gauge seems to work fine.However, there is a rough idle now and I want to think that it's the O2 Sensor
Old Oct 5, 2013 | 11:42 PM
gdog's Avatar
212 (as you know) is front O2 sensor but I would reset it at least once to make sure it comes back on before replacing w/OEM part.
Don't see how it could be related to your fan issue; possibly sticky pwr relay?
wfd
Feb 10, 2012 10:19 PM
Ed Madak
Mar 2, 2011 10:41 PM
howardc64
Forum Issues
Feb 23, 2009 10:47 AM
outdoor7or24
Sep 18, 2008 08:47 AM
markisboss
Apr 15, 2008 11:17 PM
