Trunk/Tailgate Switch
Old Jan 23, 2009 | 02:01 PM
bestharry's Avatar
Default Trunk/Tailgate Switch
Hi,
i just noticed that the light inside my trunk comes on sometimes and many times it doesnt. i checked the lamp and the switch inside the ligth assy. itself and all looks good. When i play with the wiring comming from the trunk going behind the left pannel in the trunk, it comes on and off. So, I am suspecting that the switch or some ground wire in there is making loose connection. please note that this car has been sitting for over 6 months before i picked it up about a week ago.
Can this also be making the lock functioninoperable from remote only ?- because I see some feedback going to alarm system from this wiring.
[IMG]local://upfiles/17470/063B6D4CC0274177A8F0582DADD1431E.jpg[/IMG]
[IMG]local://upfiles/17470/5A507A55D51A4877B6FDCFD6E75F0474.jpg[/IMG]
Old Jan 23, 2009 | 05:15 PM
Default RE: Trunk/Tailgate Switch
I would say maybe on the wiring. Also is the key lock turned all the way to the right?
Old Jan 24, 2009 | 07:41 AM
bestharry's Avatar
I will check the wiring for any damage when other priority jobs (PCV and Front spring seat) are done. The key lock is stuck right in the middle (If I insert the key its in vertical position and doesnt move left or right). I tried to pull the lock out y'day but couldnt get it out. but I disconnected the rod connected to it and still didnt help. I will see if I could replace the lock relay from a junkyard sometime in comming week.
Old Jan 26, 2009 | 12:52 PM
bestharry's Avatar
UPDATE!
The problem was in the trunk lock assy. probably from sitting out in the cold weather for few months. I sprayed it with some white grease and did open/close and lock/unlock with key few times and then closed the trunk. Drove the car to a plaza nearby in -23 C and as part of the habbit I pressed the lock botton on remote and, the smile was worth watching, I heard the locks working. It is working fine so far.
The trunk light still havent come ON but thats least priority for now.
Old Jan 27, 2009 | 04:45 AM
JPN's Avatar
JPN
A heart-warming smile isa nice touchin a -23C weather.
JPN
Ryan911t
Apr 13, 2014 10:19 PM
Mie518
Apr 30, 2011 02:49 PM
Vincef
Mar 18, 2009 08:42 PM
endneu913
Aug 6, 2008 05:00 AM
curtisckey
Feb 25, 2008 05:39 PM
