Turbo
Turbos? Available anywhere else then Volvo?
1. Check Ebay
2. Check this forum and Volvospeed's forum
3. Viva Performance sell the 16T, 18T and 19T turbos
Where it is leaking? It could be the RMS (Rear Main Seal) if so you can get a new one from http://www.ipdusa.com they sell the RMS's there.
1. Check Ebay
If you are led to believe that your turbo has a problem...
Does your engine use more than 1/2 quart of oil per thousand miles?
Remove the intercooler pipe between turbo and intercooler. Do you see a thick oil film inside of pipe?
Remove the turbo inlet hose between air filter box and turbo. Do you see oil puddled inside of turbo housing? Firmly pull on turbo compressor wheel. Is there a lot of slop and play in the turbo shaft?
Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to purchase and install a new turbo oil feed line.
And one other thing... For the price of a rebuilt, your existing turbo housing can be over-bored for a larger compressor wheel, such as -15G, -16G, -16T, or -17C.
Shop and compare...
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
Sales@forcedperformance.net
Rebuild@forcedperformance.net
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - Turbo@turbochargers.com
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Shop and compare...
Forced Performance
McKinney, TX 75071
Fax: (972) 984-1802
Turbochargers.com
5410 Burr Oak Drive
Fax: (713) 939-1111
1000 S. Wildwood
Suite 10
Irving, TX, 75060
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
