Turn Signal and High Beam
Hazzard Light, turn signals and high beam does not work. Also, have to push overide to shift into gear. Checked fuses all ok. Can someone steer me right. Sometimes headlights don't work unless jiggle the key and ignition switch.
ORIGINAL: mikedooley
The trans shift issue is caused my a bad microswitch, I don't know more than that.
Its all in the ignition. I have the same problem with mine. When it does that, i usually just turn back the key a bit and you see the lights come on as well as you hear the click in the shifter area. The shifter problem is connected to that.
You can probably live with it if you dont mind just turning the key back a bit.
miki425
Nov 3, 2016 08:07 PM
