update on Kristine
Old Jul 24, 2011 | 06:30 PM
radio16's Avatar
Default update on Kristine
just got the manual fuel pressure gauge installed and also got my manual boost controller in and set - running at 15 psi - ran at 17 psi for a while but toned it down coz i dont wanna drop a rodill try to post vid of the car at drag strip on friday - i wanna run it
Old Jul 24, 2011 | 11:48 PM
Vmax's Avatar
Cool, what time's your goal?
Old Jul 25, 2011 | 07:00 AM
radio16's Avatar
Default update on kristine
Realistically my first track runs 2 months ago were 10.6 to 11.45 in the 1/8 th which is the only track we hqve around here. Im hoping i can run about a9.6 to 103. at 16 lb boost which i think is max for 15 g hpt . Fuel cut from what i gather is at 16lb @3600rpm . Corrext me if im wrong though please. The fun part about it is at 45 mph ill hit the vas and the tires will spin. All stock pistons and rods so i really need to be careful. After all the work id really hate to screw the motor now coz im out of money.e
Old Jul 25, 2011 | 01:15 PM
Vmax's Avatar
Last time I ran, I got a 10.2 in the 1/8th. Still stock.
If you break traction at 45mph, you're producing a ****load of torque! Turn down the MBC a notch or two or go easy on the throttle (which is not an option), so turn down the boost, or get an ECU tune..peace of mind.
Good luck.
Old Jul 25, 2011 | 06:55 PM
clean850R's Avatar
Hey that will be good! I ran a 9.8 @ 72mph with a 2.3 60'. So you should be around there! Brake boost launch at about 2000 rpm found that to be good. Get staged and go!
radio16
Dec 23, 2010 05:06 PM
radio16
Nov 22, 2010 07:21 PM
radio16
Nov 20, 2010 11:08 AM
radio16
Oct 26, 2010 09:09 PM
radio16
Oct 10, 2010 08:42 PM
