Valve cover???
Old Dec 31, 2005 | 08:01 PM
jayad's Avatar
Default Valve cover???
My 93 850 will not start and I have narrowed it down to sticking lifters. I have heard that you cannot remove the valve cover without removing the head? Is this true.
Old Dec 31, 2005 | 10:36 PM
reg's Avatar
reg
Default RE: Valve cover???
Huh??? Sure you can take off the valve cover...........you can have it painted if you wish and not dissasemble the head!
Reg.
Old Jan 1, 2006 | 09:38 AM
JimKW's Avatar
Well these cars really do not have valve covers. They have the lower portion of the head and the upper portion which covers the valves. I guess some people refer to the upper portion as the valve cover, and some refer to the plastic piece over the spark plugs as the valve cover. You can definitely remove the upper portion of the head w/o removing the lower portion and that exposes your cams. The cams are set up to push down on you valves via little piston like things, so there are really no lifters. If your car will not start you need to check to see if it is getting fuel, then check for spark, and most important make sure the timing belt did not break.
Hey tech look how much I learned working on my car with my son in-law.
Old Jan 1, 2006 | 04:37 PM
jayad's Avatar
Thanks for info. When I take the valve cover off (plastic piece) Where do I take the upper head piece off. Arent all those bolts holding the whole head down?? The car has fuel, timing is fine, has spark but wont start. Seems like it low on compression.
Old Jan 1, 2006 | 10:01 PM
JimKW's Avatar
There are about 30 small bolt that hold the cams into the lower head. When you take these off it will remove the upper head and expose the cams and those little piston like things that push down the valves. You will see large holes with bots in them that hold the lower part of the head to the block. The valves are in the lower portion of the head. Have you checked the compression yet? You should do that before taking the upper head off.
Old Jan 2, 2006 | 12:16 AM
But before you take it all apart disconnect the fuel and spark and crank it over a bunch of times. To get things moving good and oil flowing. Then connect everything. Then hold the gas pedal to the floor and crank it and see if it will start.
If you pull the CAM COVER off you will need to remove the timing belt and everything else.
JIM YES YOU ARE LEARNING ALOT GOOD GOING!!
Old Jan 2, 2006 | 11:00 PM
reg's Avatar
reg
............won't be long and you two will be in business!
Happy New Year
Reg.
ORIGINAL: tech
Old Jan 3, 2006 | 12:24 AM
LOL maybe
Happy New Year to you as well!!
Old Jan 3, 2006 | 11:24 AM
JimKW's Avatar
I'm too old for this business. Maybe my son in-law but not me.
Old Jan 3, 2006 | 09:03 PM
LOL
dswilkins
Jul 8, 2012 08:24 PM
lanciak66
Jan 1, 2007 06:58 PM
rob960
May 17, 2006 11:05 PM
CJE
Nov 3, 2005 08:34 PM
matthewensey
Aug 21, 2005 02:40 PM
