Very Little Heat - 96 850 GLT Wagon.......
Old Jan 2, 2009 | 07:57 AM
Febus's Avatar
Default Very Little Heat - 96 850 GLT Wagon.......
Hello everyone, I hope you all had a Happy and Safe Holiday. Well I have a 1996 850 GLT Wagon, and for some reason even when the car is fully warmed up and the temperature is on high, it only blows warm not hot. I thought maybe it could be the thermostat, so I replaced it, and no difference! I really don't know what to check next, it has antifreeze. Well if anyone can give me some suggestions on what it may be, I would really appreciate it. Thank you and have a great New Year, Nelson.
Old Jan 2, 2009 | 08:03 AM
Psaboic's Avatar
Default RE: Very Little Heat - 96 850 GLT Wagon.......
It could be that the damper/air mixing door is out of adjustment. Could also be that the heater core is blocked. Do you have the air mix **** by the center dash vents all the way to the top? IF not it will let in a lot of cold (but fresh) air
Old Jan 2, 2009 | 08:13 AM
MCC or ECC?
Old Jan 2, 2009 | 08:51 AM
Febus's Avatar
ORIGINAL: tech
MCC or ECC?
I don't even know what that means.
Old Jan 2, 2009 | 08:54 AM
MCC= manual climate control (Colors on the temp controls)
ECC= electronic climate control (Numbers for temp settings)
Sorry
Old Jan 2, 2009 | 08:59 AM
Febus's Avatar
ORIGINAL: tech
Sorry
Thanks for clearing that up for me, it has ECC.
Old Jan 2, 2009 | 09:13 AM
Ok then maybe one of the motors are bad. Is the air the same temp for both sides?
Old Jan 2, 2009 | 11:23 AM
Febus's Avatar
ORIGINAL: tech
Yes it is.
Old Jan 2, 2009 | 11:54 AM
It is odd that both motor would be bad.
Check the hoses where they attach to the firewall and make sure both of them are hot.
Old Jan 2, 2009 | 05:01 PM
Febus's Avatar
ORIGINAL: tech
It's snowing right now so I will check the car tomorrow and let you know. Thank you for your time brother I really appreciate it, Nelson.
Old Jan 2, 2009 | 09:11 PM
No problem anytime.
Old Jan 5, 2009 | 11:29 AM
Febus's Avatar
Well... I finally found the time to look at the car good, and it turns out that the overflow container was clogged with what looked like mud, the hose that runs underneath was also clogged. So I disconnected both of them and wash them both like new...lol. I replaced them and she's better then she was before this happened, now that's great heat!!! I would like to thank those of you who replied, it's good to know I have a good place to go if I ever need help, THANKS!!!
Old Jan 5, 2009 | 11:42 AM
Glad all is good now.
Old Jan 5, 2009 | 06:16 PM
JPN's Avatar
JPN
I was late for the party.
I would also consider replacing the coolant with fresh 50:50 mix, unless already been replaced.
Happy New Year,
JPN
Old Jan 6, 2009 | 08:18 AM
Febus's Avatar
ORIGINAL: JPN
Happy New Year,
JPN
Better late then never...lol. I've already done so, but thanks just the same and Happy New Year to you too buddy.
hardluck
Mar 3, 2012 02:20 PM
keaunym
Nov 17, 2010 12:55 PM
Old Blue 66
Jan 3, 2010 06:40 PM
nicolaselias
Sep 18, 2009 08:51 PM
