Volvo 850 horn doesnt shut off!!!!
I have a 1995 volvo 850 and i recently replaced the engine and now that i got the car running, when ever i turn the key on the horn starts going off and doesnt shut off with the car running unless i either disconnect it or i take the fuse out, can someone help me?
Most likely the cause is the plastic parts falling apart in the steering wheel.
See post below for a little more info. You might have to get the kit in the post to fix it. https://volvoforums.com/forum/volvo-850-16/horn-stuck-17791/ |
that or make sure that the horn isnt shorting out to the frame at all.
Follow above two suggestions. I just looked at the schematic and there is no relay for the horn.
JPN |
You can unplug them in the meantime. There is a wire spring retainer that you need to depress and then they come unplugged easily.
Jeff Caplan at www.odometergears.com sells a kit to repair the horn switch in the steering wheel. ...Lee |
