Volvo 850 oil pan
Old Jun 11, 2023 | 10:49 AM
knothead457's Avatar
Default Volvo 850 oil pan
Hi. I have a 96 850 2.4L non turbo, with a damaged oil pan. My dad has a 2002 v70 2.4L turbo. The v70 is headed for the junkyard however the oil pan is still in good condition. Is there any chance the v70 oil pan would be compatible with the 850? Thank you in advance.
Old Jun 11, 2023 | 12:16 PM
The v70 will have fittings for an oil cooler that bolts to the back of the pan - as long as that cooler is there you won't have a leak and don't necessarily need to run coolant lines to it. The 850 uses a spin on filter, the v70 a cartridge -
Other than that - it might fit. Hey take it off before it leaves and try it! You will need orings and the proper sealant.
You could call someone such a Voluparts and ask Bill if it would fit. 404-352-3402
Newport_j
Nov 4, 2020 03:51 PM
froberts37
Mar 6, 2013 09:55 AM
Bubs
Jun 18, 2012 03:44 PM
JohnM
Engine & Internal
Mar 25, 2006 02:11 PM
JC
Oct 7, 2005 11:12 PM
