Replace s40 oil pan?
Old Oct 23, 2020 | 11:11 AM
Newport_j's Avatar
Default Replace s40 oil pan?
I am The owner of a 2002 Volvo s40. It has a crack in the oil pan. I know it can be replaced, but I am wondering how much of a job that is. It is obviously a old car and I do not want to put much money, but if I can get a inexpensive oil pan and it is reasonably easy to replace then I might do it. If not then I will think of another way to deal with this.
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Old Oct 23, 2020 | 11:18 AM
It's a straightforward, relatively easy job - Just need the correct sealant (anaerobic?) , and the oring kit - make sure to keep the oil orings in position when you put it back together. They easily get moved.
Old Oct 29, 2020 | 11:21 AM
Newport_j's Avatar
Sorry to get back to you so late,but I have a few questions.The first is if I buy an oil pan, do I have to get other things such as new O-ring and screws?
Nothing from the old oil can can be used?
Also,do I have to loosen engine mounts, ac compressor alternator , etc to remove the oil pan?
Finally I would like to not buy an original equipment oil pan, they just cost too much. I would like to get a replacement from
someplace like Rock Auto. They are between $ 150.00 200.00, much more in line with what I would want to spend on an car like I
have which is a 2002 Volvo s40. It is 18 years old and I just cannot justify spending any more money on it.
Respectfully,
Newport_j
Respectfully,
Newport_j
Old Oct 29, 2020 | 12:35 PM
habbyguy's Avatar
You might find a used pan pretty cheap from a boneyard, or even eBay. I agree that spending big bucks on a nearly 20 year old car (one that's not a collectible, anyway...) doesn't make a lot of sense.
No idea about what has to come off to get the pan liberated. There won't be a problem re-using the bolts, assuming they're not horribly rusted (even if they were torque-to-yield style bolts, you would NEVER torque them enough to matter on an oil pan - they are installed with very little torque, or you risk leaks / pan damage). Just crawl under the car, and take a look at what you're going to have to move out of the way to drop the pan 4-6" (enough to clear the oil pickup tube, etc.). Most likely, there are online videos on the process.
It doesn't look like there is a real oil pan gasket (the Rockauto listing is for two O-rings only), so you'll be using a gasket-maker product from a tube. Really, that's almost easier, since it won't get bumped out of the way during installation.
Old Nov 4, 2020 | 03:51 PM
Hudini's Avatar
Can you weld the crack with the pan still attached?
Newport_j
Aug 21, 2019 11:32 AM
k1s40
Mar 28, 2019 07:20 AM
froberts37
Mar 6, 2013 09:55 AM
s40volvo
Sep 14, 2011 04:15 PM
JC
Oct 7, 2005 11:12 PM
