volvo 850 rough idle
on my volvo 850 it idles rough almost like its going to quit and i checked all the injectors and there fine and i cant find why it doesnt idle smooth
dirty thorttle?
no the cable isnt sticky
the inside of it?
no i checked it is fine when driving just rough idling
A scan maybe? usually we do a fuel injection / induction service, cleans the intake, the injectors, and throttle. other than that......
okay thanks
have you tried your air idle sensor? i would try cleaning that is a turbo or N/A
okay, where is the location of the air idle sensor and it is a turbo
right in front of the throttle body, there is the bosch unit that has a hose coming from the Intercooler piping and on the other end a hose going into the intake which controls the amount of air going thru for the idle
+1 to what shelby suggested; clean the idle air control valve.
BTW: what exactly do you mean by rough idle? Does the rpm go up and down, cycle? Or does it sound like it's running rich/lean/missing? |
How's it run when you when you accelerate?
Getting any codes? Also check the spark plugs to make sure they're clean and for proper gap. Make sure the wires & cap are good, too. |
it will probably be your air flow meter i had the same problem with mine.Unplug your air flow meter and it wont idle as normal but when u plug it back in it will go to cut out again if this happens its definetly your air flow meter.Hope this helps.
