volvo 850 rough idle
Old Jun 19, 2010 | 09:08 PM
chadman551's Avatar
Default volvo 850 rough idle
on my volvo 850 it idles rough almost like its going to quit and i checked all the injectors and there fine and i cant find why it doesnt idle smooth
Old Jun 19, 2010 | 09:09 PM
SVTfocusO3's Avatar
dirty thorttle?
chadman551's Avatar
no the cable isnt sticky
Old Jun 19, 2010 | 09:12 PM
SVTfocusO3's Avatar
the inside of it?
Old Jun 19, 2010 | 09:18 PM
chadman551's Avatar
no i checked it is fine when driving just rough idling
Old Jun 19, 2010 | 09:20 PM
SVTfocusO3's Avatar
A scan maybe? usually we do a fuel injection / induction service, cleans the intake, the injectors, and throttle. other than that......
Old Jun 19, 2010 | 09:31 PM
chadman551's Avatar
okay thanks
Old Jun 19, 2010 | 09:32 PM
91shelby's Avatar
have you tried your air idle sensor? i would try cleaning that is a turbo or N/A
Old Jun 19, 2010 | 09:41 PM
chadman551's Avatar
okay, where is the location of the air idle sensor and it is a turbo
Old Jun 19, 2010 | 09:56 PM
91shelby's Avatar
right in front of the throttle body, there is the bosch unit that has a hose coming from the Intercooler piping and on the other end a hose going into the intake which controls the amount of air going thru for the idle
Old Jun 20, 2010 | 12:07 AM
gdog's Avatar
+1 to what shelby suggested; clean the idle air control valve.
BTW: what exactly do you mean by rough idle? Does the rpm go up and down, cycle? Or does it sound like it's running rich/lean/missing?
Old Jun 20, 2010 | 02:35 PM
vjaneczko's Avatar
How's it run when you when you accelerate?
Getting any codes?
Also check the spark plugs to make sure they're clean and for proper gap.
Make sure the wires & cap are good, too.
Old Apr 3, 2011 | 03:16 PM
volvo850#1's Avatar
it will probably be your air flow meter i had the same problem with mine.Unplug your air flow meter and it wont idle as normal but when u plug it back in it will go to cut out again if this happens its definetly your air flow meter.Hope this helps.
nkinkade
Feb 28, 2014 08:49 PM
Msuperbauer
Aug 31, 2012 10:18 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
