volvo brakes?!
Old Oct 9, 2008 | 03:41 PM
KALIN850W's Avatar
Default volvo brakes?!
i have a 1996 850 wagon
i have Volvo everything that has to deal with the front brakes but ofcourse they grind..not squeak but grind. i know volvos have a problem with brake noises but i have only witnessed and heard of squealing with aftermarket items
and yet the pads have life and so do the rotors adn the fluid is good and the caliper is workign correctly..
any advice before i go to the dealer?!
Old Oct 9, 2008 | 05:13 PM
Volgrrr's Avatar
Default RE: volvo brakes?!
This may sound stupid but, have you had a look at the rearside of the brake rotor, as a lot of people simply check the condition of their vehicles brake rotor by looking at it through the area between the spokes of the wheels?
A grinding sound is usually caused by metal to metal and is usually one sure way of having to replace a scored rotor.
Old Oct 9, 2008 | 07:53 PM
Ozark Lee's Avatar
My drilled rotors have sort of a grinding sound all of the time and it is normal. I've heard the slotted rotors make a funny noise as well but I don't have any slotted rotors.
Once other note:
Don't try to change out your pads at night - in the dark. I put new pads and rotors on my Platinum by feel and managed to get the outboard pad backwards in the dark. It scored the crap out of my brand new rotor just backing out of the driveway. They stop fine after correcting the err and the embarrassing score marks are slowly going away.
I do think cocktails were involved.
...Lee
Old Oct 10, 2008 | 07:43 AM
Is there a lip on the outside edge of the rotor?
Old Oct 13, 2008 | 08:59 AM
KALIN850W's Avatar
i will check the "rear side" of the rotor and also to see if there is a lip..
funny how once i posted this thread i dont hear the noise any more..
Old Oct 14, 2008 | 08:49 AM
KALIN850W's Avatar
another question..i have a manual car and i turn off the car and coast to my parking space..lol..and then apply the brake a little..not heavy brakign at all..but a little tap..
cause the car is off and the master cyclinder si technically off cause i shut off the car..will this do any harm when i apply the brake while coasting?!
just wondering..thanks
Old Oct 14, 2008 | 08:58 AM
No you will be fine doing that.
Old Oct 15, 2008 | 08:29 AM
KALIN850W's Avatar
alright..thanks..still havent gotten aroudn to lookin at the car also
Old Oct 15, 2008 | 11:35 AM
bestharry's Avatar
But eventually you will loose power assist for the brake with engine off and the brake peddal will be hard to push.
Old Oct 16, 2008 | 08:25 AM
KALIN850W's Avatar
gotcha but it will not produce any noise..so thats no biggie
mikac
Oct 8, 2008 08:10 AM
volvo 850
Aug 19, 2008 08:12 PM
hollywood
May 24, 2008 03:58 PM
LIKEAROCK99
May 14, 2008 07:38 PM
mikaay
Apr 16, 2008 08:11 AM
