volvo head gasket & cooling system
Old Nov 6, 2007 | 06:01 AM
AlX's Avatar
AlX
Default volvo head gasket & cooling system
Volvo Head Gaskets for Better Performance
http://carsinformation.blogspot.com/...or-better.html
The Volvo automobile company, one of the leaders in its industry, has 80 years of experience in the production of luxury vehicles. Furthermore, the brand is renowned for consistently coming up with innovative components for the various car makes and models of today. It incorporates much of these new automotive technologies into its latest lines of vehicles. Thus, Volvo cars continue to enjoy the reputation of being a solid, tough, comfortable, and safe automobile on the road. The company can manufacture vehicles so powerful that can compete even compete with race cars. Although the horsepower of its units are comparable to most performance vehicles, the company prefers to veer from the tracks and opts instead to offer high-adrenaline performance through commercially-available cars.
Much of the power that the engines of Volvo vehicles produce are credited to the parts that work together in delivering optimum performance on and off the road. Among this wide array of Volvo vehicle components are the Volvo Head Gaskets. Without head gaskets, engine coolant is as good as gone and an overheated engine delivers poor power.
The Volvo Head Gasket is the component responsible for maintaining a tight and reliable seal between the engine block and the cylinder head. Through this efficient sealing function, it keeps the engine coolant, fuel, exhaust, and lubricants separated, and therefore, uncontaminated. Considered the most critical sealing application in any engine, a head gasket is made of strong and durable materials hence it is able to withstand the harsh environment within the combustion chamber. It protects even other crucial components that are adjacent to its location.
Because the Volvo Head Gasket's job is demanding and stressful, owners must be mindful of it when performing regular engine check-ups. There are times when Volvo Head Gaskets get blown due to a leak caused by extreme compression in the car engine's cylinder. This head gasket problem is usually exacerbated by the use of aluminum instead of iron cylinder heads. Although aluminum is lighter than iron, its much greater thermal expansion rate exerts a great deal of stress into the Volvo Head Gasket. A non-stick coating, such as Teflon, is applied on the surface of head gaskets to remedy this problem.
Among the problems that can be caused by a blown head gasket is compression loss. Exhaust gases also get forced into the cooling system, so there is the potential of overheating which increases engine wear as motor oil mixes with antifreeze. Once drivers begin to experience a change in the performance of their car engines, it is strongly recommended that they have the Volvo Head Gaskets checked with the other under hood components. It is important to note that one must never drive with a blown head gasket as it can cause additional and extensive damage on the other parts of the engine. With these precautionary measures followed, drivers can acquire significant time before needing the help of trusted Volvo parts dealers for the replacement of Volvo Head Gaskets. For more information about your parts needs like Volvo Head Gasket visit your trusted online source. Evander Klum is a Business Administration graduate who hails from Alabama. He enjoys extreme sports and he is also a car racing fanatic. At present, he works as a marketing manager at an advertising agency in Cleveland.
boxpin
Dec 20, 2015 05:08 AM
Reid
Feb 13, 2011 10:01 PM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
