Volvo Help in Denver
Help! A couple new problems have reared their ugly heads and i'm wondering what my options are.... my left inner tie rod has "excessive movement" and my rack and pinion is leaking from the left boot. Mechanic that discovered it during a routine oil change and tire rotation/balance, quoted me $300 labor (3 hours) + about $250 for a rebuilt steering rack.
WOW! And i'm moving this month - no way this is happening now! I have plans to take it to my Hungarian mechanic in Thornton, but wondering if anyone else has any good places for something like this? Or an advice when dealing with a "blown" rack and pinion. Can I have it removed and rebuilt? God, I wish there was a place that you could rent time with a lift - that would make this kind of work SO much easier!! Thanks for the help. |
RE: Volvo Help in Denver
Actually, 250 for the rebuilt rack sounds cheap... 300 for the install sounds reasonable. Many companies do "rebuilds" and they vary by locality (don't know who does them in the Denver area...) but be sure to check around to be sure this is a good one with a solid warranty. Also, get a "full rack" with new inner tie rod ends. When you replace the rack, be sure to have them flush the system as the old rack will shed filings throughout the system... you don't want to kill your pump and the new rack...
God, I wish there was a place that you could rent time with a lift - that would make this kind of work SO much easier!! The lift rental would have to be pretty reasonable and if it were reasonable payback just didn't come. |
Turbo:
http://www.fcpgroton.com/category-ex...137/by_year/44 N/A (Seems the same): http://www.fcpgroton.com/category-ex...136/by_year/44 The subframe has to be dropped around the R&P. If you can rent out a set of ramps or buy a pair of jack stands (approx $25 at Sears) and buy/rent a hydraulic floor jack, you may be able to do the job yourself. However, Tech says it is a PITA. If you dare to do the job yourself, I can supply the procedures & illustration. Otherwise, have it done at a shop that frequently deals with Swedish/European models. An average town shop may not be able to do the job right. JPN |
