Volvo parts questions...
Old Jan 26, 2007 | 08:58 PM
rnmdad's Avatar
Default Volvo parts questions...
Just started going through my 850, is a 1994 not a 92, in need of some parts. First issue, motor has been changed, as well as intercooler setup. I was told it's a newer styly system, upper cooler outlet goes to throttle body instead of lower. I need the tube that's attatched to the cooler, the 90 degree rubber, and the tube with the small tube that's attatched to the throttle body. Both are oil soaked, the first is split. I'm trying to spend as little as possible for temp fixes, want to upgrade this spring. I also need the PnP switch, I'll get that new, but does anyone know if that will affect the ignition cylinder? Key is stuck in. Reverse lamps also inop. I've got the 1-1-4 code for the mode switch, was told most likely cause was PnP switch. Also looking for a deck spoiler, someone decided they needed it worse than me, car is red. Any possible parts, or just must know info for a new volvo modifier would be most welcome. Thanks guys, Jeremy.
Old Jan 26, 2007 | 09:29 PM
Default RE: Volvo parts questions...
Make sure the shifter is all the way in part and the **** button is all the way out.
The key should come out then.
As for the other parts check in the General section for a Post "Links to sites"
Many of parts sites there.
T77911S
Jun 28, 2018 02:18 PM
JawdB
Jun 10, 2015 09:47 PM
TacklaNHL
Jul 29, 2012 11:20 PM
Phil 850
Jul 25, 2012 10:01 PM
andrew123
Canada, Over Seas & Elsewhere
Jan 9, 2011 05:09 PM
