Want More Air?
1 Attachment(s)
Attachment 17976
Turbo throttle body on the left, NA throttle body on the right. NA intake manifold, NA throttle body, and a S90/960 throttle plate. |
1 Attachment(s)
Originally Posted by boxpin
(Post 321327)
I dont know why you posted this but I'll join in...
Might as well throw a 960 TP on there too.
Originally Posted by 058ovlov
(Post 321372)
Originally Posted by gilber33
(Post 321308)
(Post 321376)
already said. :)
The 960 plate does not have the puck on it, N/A does. The puck helps with initial low throttle response, meaning it helps with the transition of the sharp open/close of the plate. It really does not affect the air flow since it is not any larger than the TB shaft. Most people go for the 960 plate, I have both and use the N/A.
What do you guys mean by 960 plate? I took a tb. Off a 95 960 and its 3inches so what do you guys mean ive never got this. Also why the is it tbat every 850 glt i see at the jy is non turbo today i went and there was a 96 glt non turbo i thought only the 93s were non turbo
Originally Posted by volvoguy23
(Post 321407)
The 850 N/A and the 960 throttle plate are the same diameter. The only difference is that (like Boxpin mentioned) the 850 N/A has a semicircular plastic puck attached to it. Buy either removing this puck and filling it's hole, or replacing it with a 960 throttle plate, it slightly increases throttle response. And makes it more peppy when accelerating from a stopped position. Now as to your hieroglyphic of a question above. The simple answer is that the GLT designation in early 850s' was essentially N/A. Later on that designation was reallocated to what is essentially the "between model". This will fill you in. Volvo 850 - Wikipedia, the free encyclopedia |
so then what i have now is ideal? the whole 960 tb assembly?
Thank you for simplifying this for as ive never understood lol...should i attain the n/a intake mani from a n/a 96? Also is it only the 93 850 with the "biggest cams?" If so would i benefeit anything from the 96 cams?
(Post 321414)
(Post 321421)
Its a 94 turbo wagon....and i know that the mani has to be honed out for the 960's 3in. Tb....i was just confused on the plate deal lol
O.k. We're finally starting to get on the same page. As far as the cams go, people say the '93 ones are the best. But any 850 NA cams will work. And if there is a difference, I'm sure it's negligible. As far as your manifold/TB mod. I have no idea about using a 960 manifold. Most just use an 850 NA Manifold & 850 NA TB and just swap out the plate for the one on a 960. So if you bought the 960 TB. I would just take it back, get the 850 NA manifold, the 850NA TB, and cop a plate out of a 960. Hope that helps. I have a feeling you kinda get it now that you have a better understanding of the plate.
What the hell is going on in here? lol Cams? GLTs? off topic much? lol
-Only 97 GLTs were LPT, the rest were NA. -You use an 850 NA manifold (to avoid porting out the turbo manifold), 850 NA throttle body, and a 960/s90 throttle body plate. -93 cams were supposedly the biggest, but, I'm guessing your car is fairly stock and unless your doing extreme modifications, you won't know the difference between a 93 NA cam and a 94+ NA cam. -You can't use a 960 manifold. 850 has five cylinders. I'll give you one guess how many cylinders a 960 has. -What year 850 doesn't matter, just make sure it either has EGR or SAS for your car. You may also need to tap a vac line port in the manifold. Everyone says they need to do that, I did not only because I don't have SAS, EGR, cruise control, etc etc. Does that cover all of the confusion?? I put on the throttle body last night and the response was amazing. I was breaking the tires loose easier than ever before, I didn't even have to try. It's a great mod. |
3 Attachment(s)
This is the plastic block on the throttle plate.
Does anyone know if at one point Holly made a throttle body for Volvo's? I came across a picture but never found any information or availibility on it. :confused: |
Lol thats hilarious i would never be that stupid to think a 960 mani would fit a 5cyl....i dont know where that came from but anyways i was just wondering about the 94 and up n/a cams out of curiosity. I have a 960 throttle body assembly and was wondering if i should just get a n/a mani instead of tearing up my mani.
Also dont forget if you go the N/A TB way you need to get the upgraded TB IC hose, the stock one wont fit...
I dont know who else sells them but here is the one I ordered and never used.... YET NA Throttle Body Hose for Turbos 93-97 850 |
l know this is an old thread but l saw this whilst reading on google about bigger TB. what are the benefits of changing the turbo TB to an NA TB?
| All times are GMT -5. The time now is 03:49 AM. |
