Warming a 850!
Old Dec 19, 2008 | 04:48 PM
Arsenal6's Avatar
Default Warming a 850!
It winter and it a debacle over whether warming a car is better to idle or to roll and leave it under 2500 rpm
I am told all 'fuel inject' cars are better to roll, I agree it faster but I am also told idling is bad for the engine...any takes?
(assuming all cars are fuel inject, not sure what else is there)
Thanks!
Old Dec 19, 2008 | 06:52 PM
zmontgomery's Avatar
Default RE: Warming a 850!
I always give mine a minute or two of idling before I take off, and then I drive it gently until the temp gauge comes up. Especially on a day like today (high -3degrees F)
Old Dec 20, 2008 | 08:07 AM
JimKW's Avatar
I let mine warm up very little, less than a minute, and then just drive normal. If it's real cold I do let it warm up a little longer, but not much. I am NOT saying this is good for the car or what you should do, it's just what I do. I have always thought that once the idle comes down to normal, it's fine to drive the car.
Old Dec 20, 2008 | 08:22 AM
JPN's Avatar
JPN
ORIGINAL: zmontgomery
I always give mine a minute or two of idling before I take off, and then I drive it gently until the temp gage comes up. Especially on a day like today (high -3degrees F)
I do the same.
No, it would not hurt anything to idle for warm up, except it uses excess fuel and you have 0 miles/gallon. Carbon sludge may form faster as the engine is cold & the A/F mixture is rich.
I would idle 1-2 minutes then drive gently until the coolant gage begins to rise. I wait using full power until the coolant gage is at 3 Oclock or I have driven at least 15 minutes.
This is more of a personal preference than a fact.
JPN
Old Dec 20, 2008 | 08:31 AM
Adrenalin540's Avatar
Man,
If it is like 20F I will wait 2-3 mins, if it is 10F I will wait 5-10 mins if it s OF or lower I wait no less than 10 mins. I like to ride in a relatively warm car, with clean windows and a defroster that is working. Being able to see where I am going is far more important than a little carbon, and I use 1 can of Lucas fuel system cleaner a month and at least one tank of sunoco premium, a month. I seafoam all my cars at least once per year...So, I believe I am keeping any carbon in check...
Old Dec 20, 2008 | 07:03 PM
bitter356's Avatar
+1 Adrenalin540!!!!!!!!!!!!!
Old Dec 21, 2008 | 03:19 AM
JimKW's Avatar
One thing I should add is my cars are always garaged which does make a big difference. When leaving work, if the windows are steamed I do wait for them to clear which means I warm the car longer. I keep the pedal to the metal pretty often to take care of carbon build up.
Old Dec 21, 2008 | 05:17 AM
JPN's Avatar
JPN
If you want the windshield to be clear as quickly as possible, make sure to turn on the defrost (this turns the A/C compressor on for the EEC, not sure about the manual EC) and turn off REC.
JPN
Old Dec 21, 2008 | 11:14 AM
S70driver's Avatar
FYI if you don't let your car warm up you will use more gas. How much more, I cannot say really.
If you let it warm up you will use less gas how much less I cannot say again.
So let your car warm up before driving off. 5 minutes will do fine.
Old Dec 21, 2008 | 06:41 PM
JimKW's Avatar
Five minutes before going to work. Five minutes for going to lunch. Five minutes when I leave work to come home. That's one hour and 15 minutes per week I sit in my car warming it up. I think not.
Old Dec 21, 2008 | 07:12 PM
Who sits in their car? I start it it remotely, and get ready for work...LOL, Not laughin at ya, just I'd never spend >5 mins sitting in my car to warm it...Even at work, when I leave the gate, I remote start it, if I have to scrape the windows, or dust snow etc, when I get into the car it is warmed up...
Old Dec 22, 2008 | 07:19 AM
JimKW's Avatar
To be honest I do not know a single person that has or uses a remote starter on their car. And everybody I know just starts their cars and goes almost immediately just like I do.
Old Dec 22, 2008 | 07:52 AM
S70driver's Avatar
All I was saying is that it is recommended to let your car warm up for five minutes before driving off.
1. Start it and sit there. Not that bad really. I do it everyday I go to work.
2. Bring two keys with you all the time, start it with the one and go back inside.
3. Don't warm your car up and use a little more gas, how much I don't know.
I don't have an issue with waiting in my car for five minutes. It isn't that bad really.
Old Dec 22, 2008 | 10:33 AM
wheelsup's Avatar
Oil bathing cams when cold:
http://www.youtube.com/watch?v=SmoGXRJE1_g
Oil bathing cams when warm:
http://www.youtube.com/watch?v=wVT4OYfKEx4
You can even hear the difference as the oil makes a splattering sound when warm. I let mine warm up! But then again it typically sits for 2-3 days between starts.
mpower916
Dec 27, 2012 03:22 AM
pdlarson
Oct 29, 2011 07:06 PM
mrpyromaniac
Aug 19, 2007 05:17 PM
