What the best way to stick the ceiling upholstery
3m makes a headliner/ interior adhesive you can use. It shoots out like a spray and it becomes tacky. You can buy that at Pepboys or just about any parts store.
I am going to 'chime in'...This is just one of the problems I resolved on my Car
Before:
After:
This is one of the repairs there is just no 'short cut' for. Do it go all the way otherwise you will constantly be fighting it.
There are 2 very good adhesives...as a previous poster said, the 3M stuff I believe it is 90 the last 2 digits of the part number or Loctite headliner adhesive. Both from what I understand work great...I used the Loctite...
for the repair, actually pretty intimidating but really not that much to it.
1. remove the headliner, (drop the assist handles, pull the trim off, pull the visors, I just cut the wires down the a post a little so I had a place to solder them and tape em back in place, take the headliner out through the front door, try not to bend it to much but if you do, no biggie) and you will have to bend it some...
Headliner out, pull all the fabric...now there is a 'foam backing on the headliner, get a very stiff brush, and rub it off, it is a little messy, but get it 100% off, go to the fabric store and get something you like. I didn't go 'wild' so I got some microflece, a little bit heavier than stock...I thnk the material cost me $15 or $20. Trim the material so you have slight overhang (1-2") around the edges...do not cut the sunroof opening yet...
after the headliner is clean and dusted off, take it to a 'warm place' say around 70 a good warm basement was ideal for me...lay the headliner down and the material right next to it, get a partner to assist you...follow the instructions on the adhesive, I sprayed it all over the headliner making sure to pay attention that I did not miss a spot...and hitting the sunroof opening and the assist handle openings double, With the help of your partner, both pieces covered in adhesive (not enough to soak through), and pieces being allowed to set for a min or two, begin laying the fabric in place. Make sure you have edges remaining, then press the fabric in place rubbing with your hands over every inch of the headliner pressing firmly, Allow it to 'set up for about an hour, and repeat the pressing. Take it to another spot in the basement or flip over your workmat...now around the sunroof opening cut the material so you have 2" all around. put a cut in each corner coming to within an inch of the corner, don't worry the material will stretch nicely.
Repeat the adhesive around the sunroof opening,same way both pieces and allow it to 'set up' rub it in firmly. Then, cut all the openinngs for the visors, handles, etc... at this point I let mine setup overnight.
Reinstalled it to this
Before:
After:
Good Luck!
Before:
After:
This is one of the repairs there is just no 'short cut' for. Do it go all the way otherwise you will constantly be fighting it.There are 2 very good adhesives...as a previous poster said, the 3M stuff I believe it is 90 the last 2 digits of the part number or Loctite headliner adhesive. Both from what I understand work great...I used the Loctite...
Before:
After:
Good Luck!
The Minnesota Mining & Manufacturing (3M) adhesive failed on me mere a few days later. I then tried the Loctite version and it never failed on me. They are in the similar price range so I would vote for the Loctite version.
Good luck,
JPN
Good luck,
JPN
In order to remove the sunroof mechanism you have to remove the headliner. If you're solely referring the sliding piece that covers up the glass, that piece comes out the roof and sits inside the sunroof casing. Not attached to the headliner at all. The only part you have to remove is the trim that holds the headliner to the sunroof. And be careful, it's pretty fragile.
Just replace all of the material. The stuff is so old it like deteriorates. Also, when you replace the headliner, make sure to scrape off ALL of the old foam, and either apply new foam or get the special headliner fabric that already has foam on it, otherwise you will have a poor surface for the adhesive.
I broke the trim that holds the headline in 3 places. I hope super glue can fix it. I'm looking at the loctite products online.Can you tell me which product to buy? http://www.loctiteproducts.com/contact-adhesives.shtml
I highly doubt, actually, you're not going to be able fix it. Better to source another one. The piece needs to have some flex in it to "snap" back in place, once it's cracked it won't have that flex, and super glue will just create weak points where it will break again when you try putting it back in.
rspi
Mar 3, 2014 10:39 AM
rspi
Feb 23, 2014 11:02 PM
rspi
