what rims...?
Old Nov 2, 2004 | 04:03 PM
cauqazn's Avatar
Default what rims...?
OK guys, pretty new to this forum, but just looking for some feedback on rims. I have a stock 850 GLT 1993 white volvo...I'm thinking of getting Motegi MR7's... on their site it says for 92 - 93 models "850 pin must be removed". What does this mean?
Also has anyone gotten these rims for their 850? Any rubbing off? Hows the fitment? Smooth ride? etc. ALso if anyone knows the fitment, offset, and lug pattens (pretty sure the 850 is 4lug) just reply.
Thanks for the help in advance,
-cauqazn.
Old Nov 2, 2004 | 04:46 PM
Default RE: what rims...?
I will try try find out offset and lug pattern for you.With any rim it will only ride as good as the tire mounted on it.The pin they are talking about i believe is thet alignment pin that holds the rotor to the hub.
Old Nov 2, 2004 | 05:03 PM
cauqazn's Avatar
Is the pin hard to remove? Can it be done at home or does it require professional service... ? thanks
Old Nov 2, 2004 | 05:22 PM
It can be removed at home.Once you remove the rim and tire you cant miss it.The lugs are really studs that come out when you remove them.Once you remove the rim it will be the only thing sticking out from the rotor.You will need a 10mm wrench or deep socket to remove it.
Dex2020
Feb 7, 2019 02:21 PM
KREID
Sep 26, 2005 12:49 AM
KREID
Apr 13, 2005 12:50 AM
sbrownbw
Feb 15, 2005 09:46 PM
Steamroll9
Jan 25, 2005 08:37 PM
