Wheel fitment question
Old Dec 11, 2007 | 02:42 PM
94_850T's Avatar
Default Wheel fitment question
Will wheels from a 2004 S40 fit my 94 850? Local guy is selling a set of 4 for $50.
Old Dec 11, 2007 | 02:56 PM
S70driver's Avatar
Default RE: Wheel fitment question
You need a bolt pattern od 5x108mm.
Old Dec 11, 2007 | 03:19 PM
yert315's Avatar
It depends on the model of the s40. Some of them came with a 4x114 bolt pattern and others came with 5x108. So I assume if it has 5 lugs you should be fine.
Old Dec 13, 2007 | 10:19 AM
robert213's Avatar
ORIGINAL: S70driver
Yes but, I thought that the hub diameter wasdifferent on the S40. If it is larger, then you will need hubcentric rings. If it is smaller, then you will need a machine shop toshave rim in order toincreasehub diameter.
s60t5man
Dec 8, 2010 09:42 AM
fochmann
Aug 28, 2010 09:28 PM
trueimport
Feb 3, 2010 06:30 PM
MaZoN
Feb 22, 2009 07:23 PM
Face
Dec 19, 2008 09:15 PM
