Will temperature gauge warn in time for overheating?
Old Mar 29, 2026 | 07:20 PM
dglevy's Avatar
Default Will temperature gauge warn in time for overheating?
Hello all! This is a continuation of my seized thermostat bolt saga (thread). The thermostat has still not been replaced, and I'm going to have to take it on a trip for 3 weeks. In cold weather it wasn't a problem b/c I blocked the front of the radiator so that the engine could stay toasty warm on the highway but, now that the weather is turning warmer, I'm wondering whether the temperature gauge will warn me when the coolant temperature gets dangerously high. I saw or heard somewhere that the needle rises to about 3 pm (9 pm?) when the engine comes up to temperature, but it won't rise above that. Can anyone clarify whether I can depend on the gauge (and remove the cardboard blocking the radiator in time)?
Old Today | 05:47 AM
rockdoc's Avatar
DG, it's not clear why you are worried about overheating. If you have to block the radiator to get or keep the engine up to operating temperature, the thermostat appears to be stuck open. If that's true, you should not have to worry. Running with an open thermostat is not optimal, but that should not cause significant damage the engine. I imagine your gas mileage will suffer and you could accelerate the formation of deposits. I would change the oil more often in this case, if the engine does not reach normal operating temperature.
If you are worried that it will suddenly become blocked closed, then the temperature will go up quickly. I don't know how much time you will have, but it won't be long. You won't have five minutes to figure out where to pull over. My gauge normally sits at about 3 PM or just a bit higher.
Have you thought about renting a car for your three-week trip?
Old Today | 05:27 PM
dglevy's Avatar
Thanks for your reply. Yes, the thermostat is stuck open. What I'm not clear on is when I should remove the cardboard that is blocking the radiator on a warmer day. If the temperature gauge is reliable, then I can just see it rising to a dangerous level well above 3 o'clock. But I heard or read somewhere that the needle never rises above 3 o'clock which presumably means it won't warn me when the coolant is getting too hot.
Kevin Eberle
Aug 20, 2021 01:45 AM
JasonSawyer1989Volvo
Mar 27, 2021 11:54 AM
Chuck Bailey
Apr 7, 2018 04:01 PM
akpasta
Nov 15, 2013 12:18 PM
slickz
Aug 10, 2007 10:25 PM
