Wiring diagram for ABS Wheel sensor
Old Jan 19, 2008 | 06:47 PM
dwhartwell's Avatar
Default Wiring diagram for ABS Wheel sensor
I have a 94 850 NA. The right front (pass) side ABS wires were ripped out of the plug going into the sensor. I need to know how to properly connect the wires back together. There is a brown wire and a black wire.
The plug into the sensor is labeled 1 and 2. Which color wire goes to each?
Thanks
Old Jan 19, 2008 | 07:33 PM
ShaginWagon's Avatar
Default RE: Wiring diagram for ABS Wheel sensor
Maybe have a look at the sensor on the opposite wheel ?????
Old Jan 19, 2008 | 08:21 PM
dwhartwell's Avatar
Yep, that's what I did. Pulled the other wheel, cleaned the wires, and determined the correct connections.
BROWN goes to terminal #1, BLACK to #2
Old Jan 20, 2008 | 10:59 AM
dwhartwell's Avatar
ABS is now working. Cost was time to pull apart connector, solder in 2 wires,
solder those wires to the ABS harness and shrink the shrink tube to seal.
Blkwidow
Sep 21, 2013 02:34 AM
sdl92
Jun 22, 2013 07:19 PM
emilys70
Oct 18, 2011 01:23 PM
cas1
Oct 5, 2004 10:19 PM
Erock198
Jul 31, 2004 06:16 AM
