Worth it???
Old 12-17-2008, 09:14 PM
Terpbtm's Avatar
Default Worth it???
'95 850 wagon....250k..still in good shape,runs great..now the issue..
Runs great at speed no apparent issues. once it warms up and you stop at a light and idle it begins to spout black (oily???) smoke. If you put it in neutral and advance the throttle to 1200 RPM's it doesn't smoke ( or no where nearly as bad). The last time I drove it it smoked a good deal more and even during regular driving. I was told this relates to a "bad" seal in the turbo whichs leaks improper amounts of oil.
My question is should I fix it...roughly how much to fix......can a person of very good mechanical aptitude perform this repair......or just call it and get rid of it...........what's it realistically worth????
Thanks for any input
Brad
Old 12-17-2008, 09:18 PM
Default RE: Worth it???
Check engine light on?
You might have a clogged vent system or a bad vacuum hose.
Old 12-17-2008, 09:21 PM
Terpbtm's Avatar
No check light...I work at a marine dealership and have numerous ex- auto techs in house and they all seem to point toward a turbo issue
Brad
Old 12-17-2008, 10:28 PM
TIPSP's Avatar
Got Boost?
If it is just theturbo, you could always swap it.
Buy one on this site or turbobricks for like $100-$250 shipped.
Click hereto check out what turbomodel you need.
Old 12-17-2008, 10:40 PM
Adrenalin540's Avatar
I am with Tech...I believe it is PCV related...My Dad always taught me 2 things about sales, something is only worth what you can get someone to pay for it, and people buy what they see...GL
Old 12-17-2008, 10:48 PM
Terpbtm's Avatar
Hey guys I'm not disagreeing....it my not be turbo related at all...I've never had a turbo before so it's all new to me. How would I go about resolving the issue if it's not turbo related..I assume that that is an easier fix than replacing the turbo??? Thanks again for the input.
BTW this turbo was resealed by a third party but the shop that reinstalled the turbo relly did a horrible job...loose or unattached hoses etc so I have absolutely no confidence in the repair. I had to reattached most of the hoses properly myself...this was probably 1200 miles ago
Old 12-17-2008, 11:08 PM
TIPSP's Avatar
Got Boost?
Here is a good walk-through for the PCV: http://www.lakesidedp.com/uploadpics/pcv/
Either way, both jobs require you to remove a manifold.
Edit: since the turbo was messed with by a third party and appears to have been a "crappy" job, that could have effected the turbo.
you never really know unless you check.
Old 12-18-2008, 07:45 AM
1 hose not connected for the vent system or a clog somewhere would make it suck oil into the motor and burn it like a bad turbo would.
Old 12-18-2008, 08:20 AM
Psaboic's Avatar
My suggestion, take the advice given and check out the PCV system first as it is fairly easy and inexpensive. If that doesn't help, do a full tune up. If that also doesn't help, then look into the Turbo. And yes, if you like the car and it runs well.....it is worth it
NCS60
11-01-2005 11:34 AM
NFSS40
10-07-2005 05:29 AM
volvofanatic
08-20-2005 10:09 PM
DI740
04-21-2005 11:51 PM
e
09-19-2004 10:18 AM
Quick Reply: Worth it???
