MisFire
Old Dec 16, 2008 | 04:43 PM
joefuss21's Avatar
Default MisFire
the check engine light was on and it comes on every so often after i reset it . bout 3 months ago did plugs n wires n F filter. Codes came on again today just did cap and rotor thought that may be culprit. when i scanned today i got mis fire in cyl 2,4,5. cleared them and got home before check engine light was on again. this time 4,5. Im frazzled now cuz I ive changed everything and dont know what else to change and car runs fine.
Old Dec 16, 2008 | 05:11 PM
Default RE: MisFire
OEM parts?
Maybe it is an injetor problem.
Old Dec 16, 2008 | 07:50 PM
joefuss21's Avatar
Default RE: MisFire
yes they are. any way to check if it an injector prob. I dont wanna buy brand new injectors. maybe some used ones on ebay? your thoughts thanks.
Old Dec 16, 2008 | 08:15 PM
Ozark Lee's Avatar
Default RE: MisFire
What kind of spark plugs did you use and how did you gap them? The Bosch Multiprong Platinum plugs are death as are the Bosch plug wires. The $1.00 a pop Bosch Copper plugs gapped at 0.028 work the best.
...Lee
Old Dec 16, 2008 | 08:28 PM
Default RE: MisFire
To test the injectors you would have to pull the fuel rail and have someone bump the key and watch the spray pattern.
Old Dec 17, 2008 | 07:38 AM
Psaboic's Avatar
Default RE: MisFire
First thing I would do is pull the plugs and check their condition.If ok, then I would check the plug wire connections, wire resistance, etc....
Old Dec 18, 2008 | 09:39 AM
JPN's Avatar
JPN
Default RE: MisFire
I have always had good luck with Bosch two-ground electrode platinum. For platinum/iridium I do not mess with gapping as they are factory-set and incorrect gapping may damage the centre electrode tip. However, if I were to buy plugs next time, I would go with genuine Volvo.
My 1st & 2nd replies in the following thread may be of some use:
https://volvoforums.com/m_48928/tm.htm
JPN
rmmagow
Aug 23, 2006 10:57 PM
Jul 28, 2006 04:14 AM
JIMMY
Mar 31, 2006 09:44 PM
hwy9rnr
Feb 22, 2005 10:54 AM
