2011 c30 air filter replacement
Does anyone have info on where the engine air filter box is and how to change filter. Manual shows air filter in incorrect location. Tracing the air path to box but appears to have two screws and do not want to start yanking without knowing for sure.
Volvo's free replacement is at 37,500 and I feel this is excessive for a air filter and want to change sooner.
Thanks for any info or pics.
Wino454
Wino454
Any part of the car that takes in fluids or air from the environment should have a way of separating the good from the bad, of taking in only what benefits the mechanism and leaving the rest behind. This is why cars have air filters and fuel filters. True, they require regular looking after but this is one of the simplest and least expensive — and most important — maintenance procedures you can perform for your car. Changing your car's filters on a regular basis can have a significant impact on engine life and performance.
We'd like to walk you through a basic Replacement Air Filter change. It doesn't take long, saves you money, and sends your car down the road refreshed and renewed. A clogged air or fuel filter can cause poor performance, poor fuel mileage and reduced engine life. This simple procedure guards against that.
