Volvo C30 HID (Xenon) lighting kit
Hi Guys
I recently purchased a C30 2.0 and I am interested in finding out about a HID (Xenon) lighting kit that I can install as to improve lighting. As I am not technical I would like to know if anyone has had positive experience with a kit on the C30 and if so which brand / model to look out for as well as pricing & ordering info.
Thanks! :-)
Thanks! :-)
RE: Volvo C30 HID (Xenon) lighting kit
Are you looking for OEM or aftermarket?
You can purchase an aftermarket kit for $150 with a LIFETIME WARRANTY. Which is cheap compared to what HID's used to cost. And trust me the kit is quality. I own one.
http://www.sharphid.com/
The link above is where you need to go to purchase your kit. John from SharpHID will take good care of you.
What you need... I will make a short list. You don't currently have a OEM HID setup right? If so this is what you want.
1. H11 style bulb 55w, you can also go 35w as well.
2. You want a bulb temperature between 4500k and 6000k nothing more nothing less. All you get with a higher temperature rating is a color change. The brightest or most light output is from 4500k-5000k.
3. Get the Apexcone kit from the link above. The one with the LIFETIME WARRANTY.
Thanks for the prompt reply - really appreciate that!
Does the SharpID kit differ in any way from the Volvo OEM kit in terms of performance? As I do not currently have any OEM kit for my C30 this brings me to my next question - how hard is it to install this kit and would it void my warranty on the vehcle?
Regarding your list - are all of these items included in the SharpID kit or should I order them seperately?
Thanks!
Thanks!
Just an afterthought - please could you help me regarding the major difference between the 35W and the 55W bulb?
Would both of these run at the same temperature?
Would the kit need adjustng or would it run at the ideal temperature? (between 4500k and 6000k)
Would I be able to use the original Volvo lenses? Ideally I do not want to hange anything but the bulbs as to enable the HID kit.
Thanks!
Thanks!
ORIGINAL: ntolmay
Thanks!
Thanks!
They are very easy to install. 30 minutes per side, simple. As for it voiding your warranty I cannot answer that. It may, but it may not.
ORIGINAL: ntolmay
Thanks!
Thanks!
2. The bulb temperature is exactly what it states. If you say you want 4500k that is what you will get. If you want 6000k that is what you will get. In this case bulb temperature means light output.
3. You should be able to use your OEM lenses, I don't think anyone makes aftermarket lenses yet for this model Volvo. Maybe the OEM c30's that come with HID's have different headlights, maybe you should look into buying those and putting a SharpHID kit in them.
ORIGINAL: batmanxgirl
might be a dumb questions, but what does this lifetime warranty entail??
mydepots
01-16-2007 01:46 AM
