01 C70 starting problems
My C70 tries not to start sometimes. It just cranks and doesn't turn over. Sounds like its not getting fuel. When I give it gas it turns over. Sometimes at a stop when I let off the brake to inch up it sputters. Like its going to die. Doesn't do it all the time. Took it to a Volvo shop today and since there were not warning lights on they couldn't figure out what it was. They were unable to get it to mess up while they were testing. Any suggestions?
fuel filter been changed lately?
r |
Originally Posted by reg
(Post 154668)
r |
I'm having the same problem! Sometimes it wants to start but sometimes it doesn't. It will crank over but not start. So I have to sit there for a few minutes, as long as 15 min sometimes for it to start. Took it to a Volvo shop and they couldn't figure it out. Haven't tried the Fuel filter yet, but did it work for someone with the same problem
thanks, DjMony |
Originally Posted by djmony
(Post 156677)
thanks, DjMony On an 01 could also be an immobilizer problem for intermittent starting. Antenna ring around the key cylinder is the most common component failure, 9445961. This though would not cause your car to sputter when braking. |
Thanks MKC70 for the info. The shop did mention that it could be the immobilizer and the key I had might be causing it to shut down. So I ordered a new key and had the Local Volvo dealership reprogram all the keys and the new one, but still had the same starting problem.
It does sometimes start up for maybe 1 or 2 seconds then dies, so it could be the immobilizer. Can that be taken out or replaced? thanks, DjMony |
(Post 156869)
Could this issue also be on an 2004. Ours sometimes wont start, I'll have to wait about 20 seconds and then it will usually start. Except when I took it to the tire shop to get a puncture fixed. The gal moving the car had to do it like 4 times before she could move it. Very embarrassing.
Originally Posted by BenDrinken
(Post 159955)
Originally Posted by mkc70
(Post 159981)
Yes it is possible. Make certain no other RFID tags(eg. gym key,work tag) are on the key ring as they will also interfere with the little chip in the key.
Still having the problem, and now when I leave in the morning or any time my car has been sitting for a couple hours while I'm driving it kinda cuts out. Like its put-puting along. I can still gain speed and after a minute or so it stops. But my check engine light is on and has been on for a week or so. I took it back to the Vovlo shop and even with the check engine light being on, they still tell me they can't find anything. My SRS light is now on also. They told me there's a problem with that and that my airbags won't deploy in an accident. But I'm not to sure if they know what they are talking about at this point. Volvo told me it could be the Mass Air Flow Sensor, (which I replaced about 5 months ago) but I replaced it again. And didn't help one bit. I will be changing the fuel filter and possible an O2 sensor this weekend. But if anyone has any other suggestions, please please advise. Thanks everyone for all your suggestions. |
Originally Posted by koster
(Post 160103)
(Post 160105)
Strange in that no codes are coming up. Immobilizer does not cause your car to run poorly, just makes the car start. Have someone reset the SRS and see what happens before you start buying replacement parts. Keep us posted on what you find out,
Hey mkc70 (or anyone for that matter)
(Post 156898)
Previous post has the part#. The antenna ring is the piece that you see around the key cylinder. This is the part if something were to go bad that you read about people replacing, other than the occasional key. All you need to do to replace is remove the torx screws from the bottom of the steering column shroud, and remove it. Pull antenna ring off of cylinder and unplug. Plug in new one and replace shroud. Part is not expensive and can be done by you at no cost.
(Post 189328)
I'm looking for instructions or pictures or a manual or something to help in replacing the antenna ring talked about above. Also, ideas on where I could get this part. Just any part store in town, or maybe FCP Groton. Appreciate any suggestions. :rolleyes:
Use our search engine............there is a posting on changing out the antenna. They do go bad but I truly doubt that changing it will solve your particular issues with the engine.
r. |
(Post 189580)
r. |
Starting Problems
(Post 189687)
I have to agree with reg on this one. You, Koster have stated earlier that your problem is not only starting, but almost stalling at certain points. As I have pointed out earlier, the antenna ring does not do this, but only prevents startup. If you have ever had the immobilizer fault you will turn the key to the crank position and it should start up for a fraction of a second. Trying the start position afterwards will only lead to cranking, but NO attempt to start. Bending the pins on the antenna ring plug or replacing the part have been stated as known repairs.
The only one I am left with the is the starting problem. Sometimes it doesn't want to start. And now its getting worse. Before it was just it wouldn't start for a few seconds, now its about 10 seconds or so that it just cranks. It doesn't do it all the time, and I can never predict when it will, like is it cold, or hot or something, so its hard to have someone diagnosis it because usually it won't do it for the shop. No that its getting cold her in Kansas I am really concerned with being stranded somewhere in the cold. So I need to get this fixed. Which is why I was thinking it was the antenna ring. I guess I will try that and see what happens. Thanks everyone for the advise. Much appreciated. |
(Post 189852)
I have fixed all my other issues. (https://volvoforums.com/forum/showthread.php?t=33911)
Well MKC, let's try a different tact for Koster. I'll relate my instance. I went through the antenna ring issue with no good results. Under warranty the auto (02 c70) had the immobilizer replaced..................still no go. Guess what the problem was...........when removing the "computer box" as Volvo decided that was the problem.........well come to find out the harness connector had loosened and that was my intermittent start problem. Maybe........just maybe that might be Koster's problem.
r. |
(Post 190258)
r. |
